In a roof over using archetechual shingles isn't a starter course still needed?
I just want a second opinion before i write it up on the report this afternoon. Just one of many roofing issues found ![]()
Rick Kie |
best practices do call for a starter row for sure, although I've often seen it done with a non matching left over shingle,,,are You sure it wasn't a new shingle of a different color?also starter course is turned so it wouldn't look exactly like the dimensional above it...all that said if that is an original shingle in your picture it's wrong imo...jim
dmcauley is a non-member guest and is in no way affiliated with InterNACHI or its members.
Is this architectural roof installed over an existing roof? If so, it is not supposd to be per the manufacturer.
Dennis I did read this morning I think on GAF or tamco web site they want the first course 4" high. Rick Kie |
Hi. Rickie; This may help a little. http://www.gaf.com/General/GafMain.a...ngle-lines.asp Go under Roofing ABC's Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
In addition to the above, the general rule is no warranty if applied over old shingles.
John Kogel www.allsafehome.ca |
Also take advantage of the installation video's.
We need to put together a best sites . There are so many. I started doing that last year on a wiki. |
rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
And if that is not fatty enough, let's all go for the Blood Sausge "Pork".
![]() Ok, I know. ha. ha. On a different token, try this Link; Feel free to add to it. http://www.nachi.org/forum/f23/struc...84/#post452991 Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Tear it off and do it right, no more advise needed
cduphily is a non-member guest and is in no way affiliated with InterNACHI or its members.
Ed Fako is a non-member guest and is in no way affiliated with InterNACHI or its members.
For a re-roof over an existing one layer shingle roof, you do not NEED a starter course, but the 5" exposure at the bottom row SHOULD have been filled in with a starter course if they were concerned about that hump from the transition to the second course.
Also, the bottom course should have the top =~ 2" cut off the top of it, so that all of the successive courses "Nest" into the course layout neatly and uniformly without any further hums at the transitions. But, the Primary reason for the starter course, is to ensure that there is a roofing material under the slot cutouts or at the side edge butt joints, to prevent leakage directly through those gaps. Ed |
| Building Science- research from respected sources | Brian A. MacNeish | Ancillary Inspection Services & Additional Topics | 17 | 7/12/11 7:31 AM |
| Chimney flashing photo's needed: brick and stone done correctly | kshepard | Exterior Inspections | 6 | 10/13/07 9:10 AM |
| Ice Gaurd membrane | dmacy | Exterior Inspections | 36 | 6/14/07 1:21 AM |
| Roof Repair? Maybe NO | jhagarty | Exterior Inspections | 9 | 2/15/07 2:19 AM |
