Old 3/29/07, 11:19 AM
dhelm's Avatar
dhelm dhelm is offline
Default Roof shingle blisters
Any one seen blistering on shingles like this? Anyone know the cause? I seem to be having trouble inserting a picture. Guess I need help with doing that.
Helm Home Inspection
David Helm, Owner/Inspector
http//www.helmhomeinspections.com
Old 3/29/07, 12:01 PM
Joseph Hagarty,  CMI's Avatar
Default Re: Roof shingle blisters
http://www.owenscorning.com/around/r...leshooting.asp
BLISTERING
CAUSES
Moisture in the shingle
RECOMMENDATIONS
If the blisters break open revealing the asphalt, the affected shingles should be replaced.
Consult with the manufacturer of the shingles.
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 3/29/07, 3:20 PM
Peter Doane's Avatar
Judging by the picture obviously the shingles look brittle and starting to shrink or cup under. Possibly due to extreem heat in the attic from lack of proper ventilation. IMO
Peter Doane
NACHI ID# 05120681
Old 3/29/07, 3:55 PM
Peter C. Russell's Avatar
I agree with Peter, looks like excessive heat build up but could also be defective shingles.
All shingle MFG. have their defects from time to time but if the roof is older it's probably at the end of life expectancy
Old 3/29/07, 11:13 PM
jbreazeale jbreazeale is offline
Please Note: jbreazeale is a non-member guest and is in no way affiliated with InterNACHI or its members.
Whenever I see that, I know there's going to be a venting problem in the attic. See too much of it down here, but I'm guessing it's probably not seen that often in Washington state.
Old 3/30/07, 8:12 PM
Adam D. Cole Adam D. Cole is offline
Please Note: Adam D. Cole is a non-member guest and is in no way affiliated with InterNACHI or its members.
It could be a manufactures defect. I reported the same thing before and so happened to find out that Lowes was paying for half of the replacement.
A little on the Commercial side of things. mcyr General Inspection Discussion 457 8/1/09 10:50 AM
Cracked shingles pwigle Exterior Inspections 54 4/23/09 11:52 PM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 8:10 AM
Ice Gaurd membrane dmacy Exterior Inspections 36 6/14/07 12:21 AM
Roof Repair? Maybe NO jhagarty Exterior Inspections 9 2/15/07 1:19 AM
