Is there anything wrong with using asphalt composition shingles for siding as inquiring minds want to know (ok me).
www.chicagopropertyinspection.com www.elliotthomeinspection.com www.chicagolandhomeinspection.com www.homeandcondoinspector.com www.homeandcondoinspection.com http://www.homeinspectorpro.com/ (Report Software) Bob Elliott http://www.chicagolandhomeinspector.com/ Last edited by belliott; 8/1/09 at 4:38 PM.. |
| Find an InterNACHI certified Montana Home Inspector (and anywhere else in North America) |
They look like Cra-p and it seems they always are pulling off from vertical or missing .
If the flashing is there and no leaks are present, I think I would at still write it up as a non-standard "siding" application.
Yes does have separation and metal flashing No not leaking from what I can tell though that is part of a valley that hits the chimney and that is an issue. |
Similar to ghetto brick which was used during the mid 1900's.
A architectural shingle could have some nice dimensional shadows as siding but I would think it would be difficult to seal at the vertical trims. More on asphalt shingle siding: http://www.flickr.com/groups/18518981@N00/ This is a site dedicated to preserving, in photo's, a unique building material that is slowly fading away. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Not much difference between this and a Gambrel (like a barn) style roofs(lower portions). I've seen this a few times in just this type of application. I usually mention it to the client but don't write it up.
Nothing in recommend against them though eh.
I am wondering what the pitfalls of using asphalt siding as vertical wall covering really are.? In Chicago we plenty of that stuff that is asphalt siding, but made to be siding. I think it is called insulbrick. Ok I just found in my old Carson Dunlop book that when used as siding they have a tendency to curl or lift as the sun softens the adhesive put on by the factory. They are then prone to wind damage. . Hmmmm Guess that explains a lot. www.chicagopropertyinspection.com www.elliotthomeinspection.com www.chicagolandhomeinspection.com www.homeandcondoinspector.com www.homeandcondoinspection.com http://www.homeinspectorpro.com/ (Report Software) Bob Elliott http://www.chicagolandhomeinspector.com/ Last edited by belliott; 8/1/09 at 6:23 PM.. |
Never heard it called Ghetto Brick before. |
Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
When the roof leaks, you figure it out sooner or later. If the WALL is leaking, it could do significant structural damage to multiple levels without tell-tell signs for quite some time.
Plus, most wall siding applications last longer than 12 years. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Comp shingles depend heavily on proper bonding of the adhesive strip to develop wind resistance to their full potential. Key to the development of a proper bond is the weight of the shingle pressing the shingles together while the adhesive is soft.
When the shingle hangs vertically, this weight is lacking and the chances are good that the bond will be inadequate. Most manufacturers require hand-sealing of shingles on roofs steeper than 21&12. The poorer the quality of the asphalt forming the adhesive strip, the less likely that a satisfactory bond will form on a vertical surface. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
Thanks everyone, as it is good to have the facts.
Somehow just clicking "loose" on a report leaves me unsatisfied. |
We're all waiting for one of your witty comebacks... Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
I see it used on A Frames all of the time. I also see it on mansards.
Greg Bell Titusville, Fl 02111507 Serving Central Florida
| Building Science- research from respected sources | Brian A. MacNeish | Ancillary Inspection Services & Additional Topics | 17 | 7/12/11 6:31 AM |
| Cement or asbestos/cement roof shingles | dconrad | Exterior Inspections | 6 | 1/17/09 12:24 AM |
| Roof Repair? Maybe NO | jhagarty | Exterior Inspections | 9 | 2/15/07 1:19 AM |
