Old 11/14/09, 5:48 AM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Default Roof Valley
What would write about this roof valley?
Thanks!
Mid America Property Inspections, Inc.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
KS-Radon Cert.# KS-MS-0035
KS-Termite Cert. # 18933
M0-Termite Cert. # N 5033
Find an InterNACHI certified New York Home Inspector (and anywhere else in North America)
Old 11/14/09, 7:02 AM
Default Re: Roof Valley
Closed cut valley using laminated shingles. Shingles are cut 2" off the centerline of the valley.
Looks ok to me.
Old 11/14/09, 7:19 AM
David P. Valley's Avatar
Yup, the installation of this closed-cut valley looks very good.
Old 11/14/09, 8:31 AM
Thanks!!
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
Old 11/14/09, 5:31 PM
Brian K. Smith's Avatar
Brian K. Smith Brian K. Smith is offline
Send a message via AIM to bsmith2
90% of these valleys will leak when this roof gets older......old school way of roofing out here in CA we call that a california valley.
Old 11/14/09, 6:08 PM
Brian, there is a distinct difference between our conventional closed-cut valey and the alternate closed cut valley called the "California Valley"
CertainTeed highly recommends the conventional one over the other and the 3-tab should not be used with the California cut valley.
http://www.nrca.net/consumer/technic...4267&K=4181389
Old 11/14/09, 9:16 PM
true, however in my 15,000+ roof inspections over the last 10 years I have seen both styles leak....I always use valley metal on our new roofs and weave my felt underlayment!
Old 5/9/10, 9:10 PM
Jeffrey S. Campbell's Avatar
Jeffrey S. Campbell Jeffrey S. Campbell is offline
Send a message via AIM to jcampbell Send a message via MSN to jcampbell Send a message via Yahoo to jcampbell
I've seen the closed-cut done two ways... overlapped by two inches +/- and held back 2"+/-... the tech document Marcel refers to appears to say to cut it back 2" vs. overlapped... which is technically correct?
Jeff Campbell
Campbell Property Inspections
http://www.maineshomeinspector.com
Pittston, Maine
NACHI04013010
Old 5/10/10, 11:02 PM
The steeper or higher roof should run through onto the opposing slope.
In "California" valleys, shingles are not cut at the valley. Instead, shingles on the first slope are run through onto the adjacent slope. On the second slope, a single row of shingles is then installed vertically up the valley parallel to the valley centerline with the cutaways facing way from the valley centerline and each shingle course is started at the valley and cut off at the rake.
You can identify them by spotting the bottom of the lowest shingle (in the row run parallel to the centerline) at the base of the valley. It forms a small triangle that doesn't match anything else in that area.
As Brian says, it's always a good idea to use valley metal. As Marcel says, CertainTeed does not recommend the California method, but many, many are installed because they cost less to install when the installer is not very skilled.
When work is slow, they hire less skilled peope in an attempt to stay profitable. When there's lots of work, they hire less skilled labor because they have trouble finding enough help.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 5/11/10, 8:27 AM
Ken, should a conventional closed cut valley be overlapped by 2", in the middle of the valley or cut back 2"... I see it all three ways, I though cut back 2" was the correct method.
Jeff Campbell
Pittston, Maine
NACHI04013010
Old 5/11/10, 11:52 AM
Lapped shingle drainage valleys are suseptible to leakages over time, and will not last as long as other roof shingle areas. Installations of metal valleys would be more appropriate, and would last much longer. Suggest monitor roof drainage lapped valleys seasonally. Replace if deterioration is noted.
I see many lapped valleys leak here in KC all the time after about 8 years of comp roof age. Many are standard comp, and leak at joints. Cut joints will leak at some point, and lapped will age quicker than metal and other flat shingles.
CMI, CPI, KS #0110-0094 Termite #16601
KS Radon #KS-MS-0027
BBB A+ Accredited Business
Serving the Greater Kansas City Metro Area
Eastern Kansas/Western Missouri
http://www.metrospeckc.com
"If opportunity doesn't knock, build a door"--Milton Berle
Old 5/11/10, 1:24 PM
Jeff, the proper method is like shown in this detail for conventional cut-valleys. http://www.nrca.net/consumer/technic...4267&K=4181389
The logic behind it is to keep the water shedding down the valley as much as possible and not running along the cut edge and underneath those shingles.
The top 2" of the shingles are diagonally cut to help divert the water.
That is if it is done right.
Therefore, if you pick up the shingles, you should be able too see if done right.
Old 5/11/10, 5:03 PM
Curtis M. Vilt's Avatar
Curtis M. Vilt Curtis M. Vilt is offline
Marcel I wasa taught to never seal uner a valley but to cut the tips on the cut side to stop water following back under the shingles. If that makes sense. It does work well.
Need a home inspection in New York? Check out InterNACHI's listing of New York certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/11/10, 5:24 PM
You are correct Curtis, I misspoke confusing myself with the California valley and the alternate closed cut valley where in that detail it is required.
The closed Valley application per CertainTeed does not call for sealant and requires the cut 2" diagonal off upper corner of trimmed shingle.
Thanks for correcting me.
I edited my post above to make the correction.
Shooting to begin on comprehensive new roofing courses kshepard Inspection Education & Training 4 11/7/09 2:59 PM
Before You Start Repairing or Replacing Roof Finishes from CMHC mkyriacou Canadian Inspectors 0 9/17/09 12:52 PM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 8:10 AM
Roof Repair? Maybe NO jhagarty Exterior Inspections 9 2/15/07 1:19 AM
