Old 10/9/09, 8:48 PM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Default Roof Vents
There is one turbine vent in this roof. There are soffit vents installed. NO ridge vent installed. Builder not happy!!!
Mid America Property Inspections, Inc.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
KS-Radon Cert.# KS-MS-0035
KS-Termite Cert. # 18933
M0-Termite Cert. # N 5033
Find an InterNACHI certified Alaska Home Inspector (and anywhere else in North America)
Old 10/9/09, 9:18 PM
James F. McKee's Avatar
Default Re: Roof Vents
can't blame him not much venting for that size roof....
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 10/12/09, 8:52 PM
Buck, just tell the builder it is common sense.
A proper ventilated roof will have 50% intake and 50% exhaust and on a hip roof, it is recommended to have at minimum 40% exhaust, and I doubt the one turbine will cut it.
Nice find on your part.
Old 10/12/09, 9:29 PM
Bob Elliott's Avatar
Anyone know how much airspace a turbine counts for.
I am sure with the extra draw it has more pull than a standard opening.
So if a simple opening is say 1 square foot and pretend a turbine is the same ,does it count as a bigger opening?
Old 10/12/09, 9:41 PM
Bob, this is what this size vent produces.
Now you can compare this to the manufactures free air ventilation from lets say Cor-A-Vent and compare.
Diameter 8 Inches, Air Flow 4 Mile Wind 255 CFM
Building Science- research from respected sources Brian A. MacNeish Ancillary Inspection Services & Additional Topics 17 7/12/11 7:31 AM
Before You Start Repairing or Replacing Roof Finishes from CMHC mkyriacou Canadian Inspectors 0 9/17/09 1:52 PM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 9:10 AM
Roof Repair? Maybe NO jhagarty Exterior Inspections 9 2/15/07 2:19 AM
