Go Back   InterNACHI Message Board > Specific Inspection Topics > Exterior
Exterior Contains discussions about the exterior portion of a home inspection. This includes roofs, gutters, downspouts, decks, patios, windows, et cetera.
Old 11/23/07, 9:40 AM
Gary E. Sloan's Avatar
Gary E. Sloan Gary E. Sloan is offline
Default Roofing Discrepancies--Experts Chime In Please
Everyone,
Subject house is a 2000 model with a 12:12 pitch (I did not climb for reasons I'll share later)
Photo 1: Exhibits curling and vertical banding (not sure if that's the right terminology). Can anyone offer an explanation on this, please?
Photo 2: Shingles are releasing in groups and sliding down the roof along with gravity. After sampling at several locations around the roof, I learned the roofing contractor used an air gun to attach the shingles. The nail heads completely or partially penetrated the shingle rendering its attachment marginal at best. The client is at a huge disadvantage and of course the builder is hoping to manage a very distant relationship on this one.
Photo 3: Just a few shingles exhibited this condition. Can someone kindly offer the reason for the wear/failure please?
Thanks in Advance,
Gary
ID:	16247   roofing-discrepancies-experts-chime-please-dsc08348-small-.jpg.JPG
ID:	16248   roofing-discrepancies-experts-chime-please-dsc08346-small-.jpg.JPG
Old 11/23/07, 9:49 AM
Barry Adair's Avatar
Default Re: Roofing Discrepancies--Experts Chime In Please
Search racking method of installation on this board or the web. It's common but not viewed as the best method by many for obvious reasons.
Curling at the rack seams is sometimes due to tight fit expansion and nowhere for the shingles to go but buckle at the seams. Poor fastening will account for a majority of the problems seen.
badair
ADAIR INSPECTION
972-487-5634
Residential-Commercial-Construction-EIFS-Infrared Thermography
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
life is the random lottery of events followed by numerous narrow escapes...accept the good
Old 11/23/07, 10:58 AM
And not recommended for most shingles by the manufacturers!!
Sheesh!!! How bad can it get out there?
Old 11/23/07, 11:27 AM
Bad install would be an understatement on this photo.
Rip it out and start anew would be my suggestion.
steep pitched roofs and high wind areas use 6 nails per shingle.
They got carried away with these nails guns again and not set right to prevent blow outs.
The main drawback of pneumatic roofing nailers is their inconsistency in nail depth. Sometimes the heads stick up a little and sometimes the heads tear into the shingle. Another frequent problem is that nails sometimes enter the roof at an angle, which makes the head stick up. Protruding nail heads can tear the shingle above them, and it stands to reason that they don't hold as well as properly nailed shingles. In my opinion, hand driving roofing nails gives a superior level of quality... it just takes much longer, perhaps two or three times as long.
A little dab-a-dua of roof cement is also required due to the wind conditions at that steep pitch.
What is wrong with these guys?
Unbelieveable.
Marcel
Cyr Home and Commercial Property Inspections
IAC2 Certified
NACHI04070211
http://co.nachi.org/inachiawards
Commercial Builder
CertainTeed
Master Shingle Applicator
Shingle Technology
Ouellet Associaties Inc.
http://www.oaconstruction.com/
Old 11/23/07, 12:38 PM
Dale Duffy's Avatar
Recommend a licensed roofing contractor tear it off and start over.
I would not recommend further evaluation---RIP it off--Do it right...!!
Old 11/23/07, 12:51 PM
Peter C. Russell's Avatar
Ditto to the above, I think I know the name of that roofing company........
Acme-Hack em
Old 11/23/07, 1:00 PM
Acme-Hack em
Have your roof all in our back pocket Company and then we walk.
HomeOwners beware;
Marcel
IAC2 Certified
NACHI04070211
Commercial Builder
CertainTeed
Shingle Technology
Old 11/23/07, 1:02 PM
Carl Brown's Avatar
Carl Brown Carl Brown is offline
Don't ask Brian! Thats a big can of worms!
Old 11/23/07, 1:07 PM
Just imagine the absolute worst case scenario, multiply that by infinity³ and you've just begun to scratch the surface
I can't imagine why the 12:12 wasn't climbed
badair
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 11/23/07, 1:10 PM
Carl Brown's Avatar
Barry,
Those would be some BIG numbers!
Just the surface!
Old 11/23/07, 1:14 PM
Originally Posted by cbrown1
Barry,
Just the surface!
EEO I didn't want any discrimination flak
badair
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 11/23/07, 1:18 PM
And the only one that gets burnt out of that equation is the HomeOwner trying to sell the property.
Those that have done the work are long since disappeared down the highway looking for another sucker.
When will some control take place for this kind of sh$t?
Doesn't make sense does it?
Marcel
IAC2 Certified
NACHI04070211
Commercial Builder
CertainTeed
Shingle Technology
Old 11/23/07, 1:27 PM
found the solution for setting the nailing pressure
use a hammer!
badair
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 11/23/07, 1:30 PM
Carl Brown's Avatar
Barry,
That makes me wonder what the rods in my neck look like!
Whats a hammer??
Old 11/23/07, 1:53 PM
Ouch, that has got to hurt big time.
Marcel
IAC2 Certified
NACHI04070211
Commercial Builder
CertainTeed
Shingle Technology
A little on the Commercial side of things. mcyr General Inspection Discussion 457 8/1/09 11:50 AM
Asbestos jlybolt Exterior 38 7/17/07 2:13 AM
Ice Gaurd membrane dmacy Exterior 36 6/14/07 1:21 AM
NACHI Chicago Education Meeting - Roofing wdecker Education 0 10/6/06 12:03 AM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
