Well, just one tip really
| Need a home inspection in Texas? Check out InterNACHI's listing of Texas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
That looks like my old place at 8607 East Dianna Dr.!!
Lupe was asking after you Linas.
She's gonna have to fight R.A. Bob for him!!!
Ahhhh...I have fond memories of Lupe... and her sister Maria.
Brian I am not all that familiar with tile.
What is the proper underlayment for tile? What is the proper roof structure for tile? Obviously the asphalt shingle and the bracing on the existing framing is wrong. |
The main concern is the difference in weight. Concrete Tiles weigh more then Shingles and the framing needs to be designed to carry the load. As a run of the mill Home Inspector myself, there is no way for me to determine if the roof framing was engineered/designed to support Tile. For all I know this roof MAY have been installed by a Roofing Contractor and they MAY have taken the extra weight into consideration. Then again, who knows? I recommended that any and all paper work concerning the roof be reviewed, and if that was not possible then the roof should be evaluated by a Roofing Contractor with remedy as necessary. |
I doubt very, VERY much any roofing system designed for asphalt shingle will have the structural strength to support concrete tile, not even close. IMHO
Brian
Thanks for the info on the roof, and what do you mean run of the mill inspectors I am glad I only see 1 out of 1000 roofs being tile. I have enough trouble with asphalt. |
The problems with changing to a heavier material are often framing settling causing drywall cracks rather than the inability of the roof framing to support the additional structural load. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
Something a lil outside of SOP, just an "FYI", but a tip given to me from a Truss engineer. There are times when a homeowner "could" track down the truss specs for the subject home when there is no paperwork.
On the King post of a truss, many times the manu. info is stamped. Or if it is thought they were manufactured locally, there are stamps/letters on the webs that a truss engineer could point someone in the right direction for. IE you call Anyville truss and tell them a "CL" is stamped on the web, they respond. "Not mine, that's Anywhere Truss Co's metal". I've done this on repairs for trusses, I wouldn't interpret for a HO on an inspection for obv. reasons, but the more info in one's head can be helpful at times. If a truss co or engineer of record could be found for a specific installation/address, they may be able to tell someone whether the truss was designed for Heavyweight installations. They will also generally provide a statement of fact or assist with design of engineered repairs for their trusses. Outside of that, SE is needed. Just some info. |
| Shooting to begin on comprehensive new roofing courses | kshepard | Inspection Education & Training | 4 | 11/7/09 3:59 PM |
| Before You Start Repairing or Replacing Roof Finishes from CMHC | mkyriacou | Canadian Inspectors | 0 | 9/17/09 1:52 PM |
| Comp shingles over wood shingles | Matthew Hopkins | Exterior Inspections | 28 | 10/16/07 12:19 PM |
| Ice Gaurd membrane | dmacy | Exterior Inspections | 36 | 6/14/07 1:21 AM |
