Old 9/24/09, 7:03 AM
John Evans John Evans is offline
Default Saturated Window Facing Trim
Any thoughts on what is causing the facing trim to hold high levels of moisture? The highest levels were measured at the bottom horizontal trim, especially directly below the vertical sections. Trim was painted 3 months ago, note the rust at the nail heads. Same problem at another set of windows, same wall.
[Maryland Home Inspections
www.aimhomeinspection.com
Infraspection Certified Level 1 No. 7801
Old 9/24/09, 7:49 AM
Shawn Rowe's Avatar
Shawn Rowe Shawn Rowe is offline
Default Re: Saturated Window Facing Trim
I can't tell you for sure but there "ain't no" z flashings and the caulking is totally wrong. They butted the trim board to the window without proper spacing for sealant. Looks like they have the board cut exposed (and probably not primed or painted).
Shawn Rowe, CMI
HomeFirst Inspection Services, LLC
- InfraRed Specialist (Level 1 & Building Science certified)
- Code Certified Residential Building Inspector
- Certified Master Inspector
-- Serving NE Florida, St. Johns, Duval, Flagler, Putnam counties --
Need help flashing top of replacement window on brick wall !!! Bill Featherstone Exterior Inspections 5 6/26/10 11:25 PM
Broken exterior brick window ledge acatterton Structural Inspections 6 5/29/09 7:12 PM
Leak in bay window with copper roof hmiles Exterior Inspections 19 11/22/08 9:37 AM
CPA of Health Canada reminding us of corded window coverings. gromicko Canadian Inspectors 4 4/23/07 8:31 AM
Vinyl siding window trim jclark1 Exterior Inspections 14 6/6/06 10:46 PM
