Old 2/3/09, 11:23 AM
Default Sealing Exposed Nail Heads
I've always considered it necessary to caulk any exposed nail heads on a shingle roof - there shouldn't be many.
I heard an opposing opinion recently. The claim was that nails have to pass through a minimum of two layers of shingles. The shingles are asphalt backed and this asphalt forms an adequate seal around the nail.
I must admit I've seen many builders that do not seal the nail heads.
I suppose there are differing views on this but does anyone know from actual experience whether unsealed nail heads leak?
Old 2/3/09, 11:28 AM
mnahrgang's Avatar
Default Re: Sealing Exposed Nail Heads
probably won't leak right away, but when the head starts to rust, and allows water down to it's stem, then it could. Expansion and contraction will also cause some movement on and around the nail. This may break that seal.
I wouldn't argue with anyone over it, because it's not really a huge deal, but it is just a good idea.
Mark Nahrgang
www.HeyMark.info
Old 2/3/09, 11:49 AM
Michael R. Boyett's Avatar
Go order the Certainteed "Shingle Applicator's Manual" that is referenced in another recent thread. Refer to pages 82, 84 and other pages as well.
Excellence in Inspections
Mike Boyett, TREC #7290
mikeb@capcityinspections.com
Capital City Inspections
Austin, Texas
(512) 577-2579
Old 2/3/09, 1:15 PM
Doug Edwards's Avatar
I'll have to find the photo but I have one where on the top the roof it shows a small hole where the nail used to be but from the bottom inside the attic you can see a tiny spot of daylight through the hole, and then around the hole for about two feet in all directions, wood rot and mold, including the rafters. I point it out on the report as a minor item that can develop into a major if left unresolved. My brother was a professional roofer for many years and he hates it when he sees it. Calls it unprofessional and lazy, but then his butt is tighter than even mine. His solution is to seal it with roofing bull and then to take two pieces of the scrap shingles and rub them together over the spot until the minerals cover the spot completely making it disappear and blend right in with roof. You should see my new roof that he and I installed. It is a thing of beauty.
- John Stuart Mill
Old 2/3/09, 1:35 PM
iniquette's Avatar
iniquette iniquette is offline
Send a message via ICQ to iniquette
Perfect answer Doug. I used to take granules from the gutter and do the same thing when sealing the nailheads. I don't understand why you would not seal these as a roofer. you spend all week putting a new roof on for someone, and then on the last day, you shank it, cuz you don't want to go get the caulk gun or trowel? I don't get it.
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Active Rain Network
INACHI Awards Portal
Want To Exchange Links?
What we've got here is......failure......to communicate.....
Old 2/3/09, 1:51 PM
Christopher Currins's Avatar
It may not appear to be a huge deal at the moment, but it sure could turn into one. IMO exposed nail heads should be covered with an acrylic water proof sealant.
Christopher Currins
Certified, Licensed
Old 2/3/09, 2:03 PM
James F. McKee's Avatar
it has been my exprience that un treated shiners will leak with time...even treated they should be checked every couple years along with the rest of the roof for caulk shrinkage ...
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 2/3/09, 2:12 PM
That's Certainteed's recommendation as well.
Austin, Texas
(512) 577-2579
Old 2/3/09, 4:42 PM
Peter C. Russell's Avatar
All week to do a roof? jeez, we do them in a day!!!!!
Just kidding. You make a good point, why go through all the hard work and leave out the easiest part. Makes no sense.
Old 2/3/09, 5:35 PM
iniquette's Avatar
Well Peter, getting up that ladder with a sore back, bad knees, hangover and trying not to spill your darn beer takes time!! And time is money right?
Ian Niquette
Markesan WI 53946
Active Rain Network
Old 2/3/09, 5:54 PM
Mathew Hawley Mathew Hawley is offline
They should be sealed. As the shingles get older and more brittle water seapage can occur around the fastener penetration.
Priority Home Inspections has teamed up with the Dish Network to give you a FREE Dish Network system. Log onto www.Free-Dish-For-You.com for all the details.
Priority Home Inspections, Inc.
321-368-9921
www.BrevardHomeInspector.com
www.AvoidAMoneyPit.com
www.BrevardInsuranceSavings.com
www.BrevardBuildersWarranty.com
www.PrioritySignPosts.com
Info@BrevardHomeInspector.com
Old 2/3/09, 6:10 PM
You hit the nail right on the head.
Sorry, couldn't help myself
Old 2/3/09, 6:16 PM
"Usta could" do a lot of things in a day that now takes a week. You know what I mean. Now that I am a little older I don't care as much neither.
This says it all.
http://www.youtube.com/watch?v=f9f-lXqUZ18
- John Stuart Mill
Old 2/4/09, 8:36 PM
Allen L. Catterton's Avatar
Allen L. Catterton Allen L. Catterton is offline
I mostly see the exposed nail heads at the ends of the cap shingle laps. I carry a can of the rubberized auto undercoating that can be found at most auto parts stores. It does a great job, is designed for exterior use and has a relatively long life span. It comes in a spray can and after using it, it can be upturned and the nozzle can be cleared just like a spray paint can. I keep it in the back of my jeep.
I know—I know—we are not supposed to perform any repairs but I do this rather than list it as a maintenance issue since the majority of my clients cannot or will not go on the roof. The buyers are always appreciative.
Old 2/4/09, 8:52 PM
Michael W. Gault's Avatar
Michael W. Gault Michael W. Gault is offline
Not a bad thing... I fix a lot of little crap that I'd rather not write up!
Who among us hasn't used a screwdriver handle to whack down a hinge pin? let him cast the first stone...
- Mike
Michael W. Gault, SC RBI 1728
A to Z Home Inspections
Charleston, Dorchester & Berkeley Counties in S.C.
NACHI05040682
www.atozinspector.com
(843) 442-9755
Charleston Home Inspector
Help. What is the correct way to report a breaker that is too big. gromicko Electrical Inspections 77 5/10/12 6:13 PM
Yep, The plastic Nail mcyr Structural Inspections 6 3/23/08 10:53 AM
Nail pops at the base of vaulted ceiling-no roof leak kshepard Interior Inspections 32 9/9/07 2:06 PM
Massachusetts Board of Registration of Home Inspectors jtedesco1 Legislation, Licensing & Legal Issues for Inspectors 0 2/14/06 3:38 AM
