Townhomes, 75 units. Relatively new. Did they make a major mistake?
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net Last edited by jpope; 4/1/07 at 3:51 PM.. |
Not as long as you never open that window and disregard any kind of standards.
If you do that, it's all good. Jeffrey Wortham ANS Inspections, Inc. www.ansinspections.com 630.276.8440 638 Langford Drive Bolingbrook, IL 60440 NACHI ID:04050181 |
Perhaps you could lend a chimney stretcher to the builder they are very similar in appearance to a pipe stretcher for use when you cut the pipe to short, will extend the pipe to any length needed </IMG></IMG> Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
April fools
It was a "fake" chimney stack. Absolutely nothing vented through it. The fireplace was just a vented gas appliance. But I didn't realize this until after I took the first two pictures. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
| Fetch Report problem | mhazelwood | Miscellaneous Discussion for Inspectors | 7 | 11/12/07 12:12 PM |
| Is MAC a problem | bemelander | General Inspection Discussion | 2 | 9/6/07 12:34 PM |
| Camera Problem | nwagner | Miscellaneous Discussion for Inspectors | 19 | 7/30/07 11:10 PM |
| Plumbing problem at home. | mnahrgang | Plumbing Inspections | 25 | 7/10/07 6:32 PM |
| Very tough problem | Albert Detorre | Inspecting HVAC Systems | 7 | 2/23/07 1:01 PM |
