Old 11/1/08, 12:25 AM
Carl A. Brown's Avatar
Default See any problems here?
Will this fail if so why?
Old 11/1/08, 12:30 AM
Default Re: See any problems here?
Old 11/1/08, 12:39 AM
Old 11/1/08, 12:42 AM
Old 11/1/08, 12:46 AM
After it is lathed for stucco.
Old 11/1/08, 12:47 AM
Rot really will not be a problem! Right??
Old 11/1/08, 12:49 AM
James F. McKee's Avatar
yes the pictures keep changing before anyone can type a response...that is a problem....
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 11/1/08, 12:50 AM
I will wait then.
Thank you.
Old 11/1/08, 12:54 AM
just bustin your chops Mister Brown however each of those pictures pose a number of problems involving future water intrusion, but of course i think you knew that....jmo...jim
Jim Mckee
Amherst, Ohio
Old 11/1/08, 7:48 AM
Jim,
How long do I need to wait?
Old 11/10/08, 5:57 PM
dbucknavich dbucknavich is offline
Please Note: dbucknavich is a non-member guest and is in no way affiliated with InterNACHI or its members.
OK Carl its been a week and no one has stabbed. I'll bite. The first pic I will question the attachment method for the tyvek.
Old 11/10/08, 6:01 PM
Fortunately, it never rains in Kansas...so it wouldn't be a problem.
Old 11/10/08, 6:11 PM
Lack of and or inadequate flashing.
The concrete porch is poured against the Tyvek.
The front gets stucco there for the 2nd layer of moisture barrier needs to be installed behind all the trim and in a ship lap fashion.
The oval window has no backer rod and sealant joit between the trim and the window.
The way the columns are built with the wood going down into the concrete instead of a shelf/shoulder being built up 6-8" when the porch was poured so the sheathing and the stucco would have proper clearance from the porch, 2" on the solid surface.
Along with the wall where the porch touches the house.
Old 11/10/08, 6:24 PM
Dale Duffy's Avatar
Carl in my opinion it would be better to just tear the entire house down now instead of waiting a couple years when it begins to fall down from rot which will be present in so many locations I would not want to even start noting them here on this MB.
If this was a paid inspection I was doing of these home(s) I would tell my clients if major repairs were not made before the stucco was applied to rip the buyers agreement up right in front of the job superintendent--- and throw the pieces at him.
That is a disgrace to the building profession, the whole kit and caboodle---
Old 11/10/08, 6:35 PM
Jae,
It rains in Kansas.
Preventing Moisture related Problems mcyr Ancillary Inspection Services & Additional Topics 1 12/19/07 9:30 AM
Tidbits from the ASHI Message Board jbushart Miscellaneous Discussion for Inspectors 124 4/27/07 12:05 PM
CBC - Province called on to force home-sellers to disclose property's problems rwand1 Canadian Inspectors 2 4/5/06 9:40 PM
