Old 7/15/09, 5:18 PM
Bob Elliott's Avatar
Default I see several issues with this Deck
ID:	30115Just curious what the Brethren see.see-several-issues-deck-dsc00472-medium-.jpg.JPG
This Deck seems dangerous and wonder if see-several-issues-deck-dsc00488-medium-.jpg.JPG
ID:	30114would like to see how many defects they spot from pics.?
Find an InterNACHI certified Idaho Home Inspector (and anywhere else in North America)
Old 7/15/09, 5:30 PM
Michael Roberson's Avatar
Michael Roberson Michael Roberson is offline
Default Re: I see several issues with this Deck
Pic 1, Nailed not lagged to the house
Pic 2, post is lifting or not in the ground right,
Pic 3 not sure
Pic 4 Cant recognise
Pic 5 Railing configuration, nailed on? Not fond of that type of setup, only works with screws, and the occasional 2x4
Old 7/15/09, 5:34 PM
Pic 3 not sure
Pic 4 Cant recognize
Check joist /beam connection I will add a different angle
Any comments on stairs?
Check posts (whole thing lifted easily)
Old 7/15/09, 6:12 PM
Nice deck Bob
List of what I see.
Toe nailing missing @ joist hangers
Split joist
Knot hole at top of joist may exceed allowable limits
Ledger nailed with air gun instead of lags or bolts
No visible sign of ledger flashing
Framing lumber is of #2 framing grade in lieu of PT lumber
Post base broken and post unsecured
Risers appear to exceed 7-3/4" in height
Improper post to beam connection
Cantilever exceeds the 1 to 4 rule
Missing hangers at band joist
Beam splice not in center of post
Possible missing center stringer, dependant on width of stairs
No rail post on the railings and hand rails.
Hand rail not grippable.
Missing the 1" nosing overhang on the treads. Nails sticking out of rail and pulled away from wall.
Improper attatchment of stringers to deck connection.
Ok, how many did I miss?
Nick Gromicko's Avatar
Nick Gromicko Nick Gromicko is online now
I don't see a single guardrail post, just 2"X 4" stair handrail posts. Are there any guardrail posts?
www.nachi.org/deck-inspections.htm
Find a Home Inspector
Old 7/15/09, 6:27 PM
Joe Funderburk, CMI's Avatar
Is it treated wood? Sure doesn't look like it.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 7/15/09, 6:30 PM
Hahaha
Good catch as all they did was shoot a couple screws through the end balusters.(started cracking when I applied horizontal pressure)
Never would have made 200 pounds pull.
I told my client not to have any deck parties just yet.
Old 7/15/09, 6:34 PM
Originally Posted by mcyr View Post
Nice deck Bob
List of what I see.
Split joist
Wow can I paste into my report?
Good job Marcel!
I missed a couple.
What do you mean by cantilever as this is free standing (especially with those nails at the ledger) hahaa ? (double ledger) (loks like they kept the old one which was bolted behind it)
Old 7/15/09, 6:43 PM
Good job Marcel!
I missed a couple.
Well, the third picture seemed to indicate the framing cantilevered over the last beam support, could not see as a whole. Might be wrong then on that one.
Old 7/15/09, 6:54 PM
I do not believe it was Joe.
Lost that one in all the other issues.
Old 7/15/09, 6:58 PM
Need to run on an after rush hour inspection but here is a over view.
Hope this Developer does not toss me out like the last one this morning.
Will tell that story later (met him last year)
Old 7/15/09, 9:50 PM
Jeffrey R. Jonas's Avatar
Bob,
I assume you mentioned the placement of the A/C condensing unit...
From one manufacturers tech manual...
https://www.acwholesalers.com/EasyEditor/assets/ssx14_tech.pdf (page 4)
Special consideration must be given to location of the condensing unit(s) in regard to structures, obstructions, other units, and any/all other factors that may interfere with air circulation. Where possible, the top of the unit should be completely unobstructed; however, if vertical conditions require placement beneath an obstruction there should be a minimum of 60 inches between the top of the unit and the obstruction(s).
The specified dimensions meet requirements for air circulation only. Consult all appropriate regulatory codes prior to determining final clearances.
Old 7/15/09, 11:29 PM
Originally Posted by jjonas View Post
Bob,
I do not really feel there will be impeded air flow at the location however you do make me remember there is a vent opening for a future dryer nearby.
Old 7/15/09, 11:44 PM
rmaday's Avatar
rmaday rmaday is offline
Please Note: rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
Who let you out of the city?
Was this in Lake County?
Old 7/15/09, 11:50 PM
Cute
CCHills
I was in Dapkus /Merino land
Check The Deck wdevries Canadian Inspectors 1 7/9/08 2:00 PM
Deck issues mlarson Structural Inspections 15 6/26/08 6:21 PM
DECK FRAMING/CONSTRUCTION COURSE March 27, 2008 ksitzes Exterior Inspections 1 3/4/08 5:49 PM
State of Illinois issues InterNACHI Deck Framing course license. gromicko Legislation, Licensing & Legal Issues for Inspectors 4 1/16/08 10:43 PM
Max load allowed on 2x2 ledger bking Structural Inspections 4 12/23/07 2:05 PM
