The home was built in 1900. Home has visible 1X wood in the unfinished attic.
Roof appears to be 2 layers of asphalt. Is the roof decking(Sheathing) that is visible between the 1X a wood shingle roof? The stated 13 year old roof did not look as it was installed properly. Looks like the 2nd roof or sheathing was deteriorated or buckling. Any thoughts? Thanks |
The sheathing 4X8 or strips installed between or over the 1X is usually the typical(proper way) to
prepare the roof decking for installing an asphalt roof. This was from a house I did this week. Thanks for your opinions, expertise & comments. |
Personally, I wouldn't do it that way but I believe some manufacturers allow it. It is not a sensible practice, IMO. Check this link: http://www.nachi.org/forum/showthrea...=wood+shingles InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
"Is the roof decking(Sheathing) that is visible between the 1X a wood shingle roof?"
Yes, that is how they used to do them. |
Ed Fako is a non-member guest and is in no way affiliated with InterNACHI or its members.
When you see cedar shingles or shakes installed on top of standard plywood or OSB deck sheathing in todays times, unless thery have cedar breather under them, they are destined to prematurely curl and bow and split all over the place in less than 20 years. Ed |
I was referring to installing asphalt shingles over wood shingles. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Regardless of the underlayment or the number of layers the shingles pictured # 3 should be considered for estimates and proper replacement installation.
| Use of ThermoPly without underlying structural sheathing? | koconnor | Structural Inspections | 12 | 10/16/07 7:52 PM |
| Exterior sheathing | adooley | Exterior Inspections | 8 | 2/16/07 9:42 PM |
| Why different wall sheathing types? | jfunderburk | Structural Inspections | 9 | 2/26/06 7:50 AM |
