Other than the fact that it ugly is there anything wrong with this install. Its an overlay, one layer of singles lies below. The roof very new and the rest of the install looked great. New open metal valleys, all of the vent stacks & penetrations were freshly painted. Only thing that comes to mind is if the singles fail while under warranty they might not honor the warranty based on the fact they were not installed per manufacturers guidelines. Thoughts....
Foxe Smothers ( Owner / Inspector ) Pelican State Inspection Your Best Choice for Home Inspection in the Shreveport & Bossier City Area! www.PelicanState.Net www.ShreveportHomeInspector.net www.BossierCityHomeInspector.net foxe@pelicanstate.net LSBHI #10399 |
Was there drip edge below from the previous roof? Maybe they were covering some damage up. |
next big wind and they are gone......
I could not find any damage below that they were trying to cover up. The next course of shingles appeared to be correctly positioned for a first course. It looked as if you could remove the overhanging course and still have the correct overlap. Either way I told them the roof was not correctly installed.
Thanks Guys! Foxe Smothers ( Owner / Inspector ) Pelican State Inspection Your Best Choice for Home Inspection in the Shreveport & Bossier City Area! www.PelicanState.Net www.ShreveportHomeInspector.net www.BossierCityHomeInspector.net foxe@pelicanstate.net LSBHI #10399 |
I think the installer new he needed a starter course under the first course, but ran out of blades for his utility knife.
Marcel |
Real nice Dave;
You forgot the drip edge, you must be slipping. Marcel |
There...Is this better?
Wowwww! man your good.
You even have the gutter installation and fascia board on this one. How the hell do you do that, anyways. ha. ha. I have a hard time to send a picture off my digital. Marcel |
Steve Boozer is a non-member guest and is in no way affiliated with InterNACHI or its members.
Never like 2 layer roofs. They did not cut off the tabs on the third course on the original roof. Your supposed to do that first and trim off the shingles flush with the edge of the roof. If you don't cut off the third course tabs it will make a big hump at the edge of the roof which is not good especially with pitch on this one. You can also raise the shingles where they need to be instead of lowering the overhang if you remove the third course. Either way, it's crappy with or without drip edge. Look how awkward the valley bottom looks. And if they ever put gutters on, the debris will get trapped in behind the aggressive overhang and be a pain to clean.
Poor installation and definetly requires installation of gutters.
lagudo is a non-member guest and is in no way affiliated with InterNACHI or its members.
I agree that it is a bad install but why do homeowners not take the time to do there homework and get the correct information they need to make sure they are making an informed decision. I understand that they think they are hiring a professional who knows what they are doing but shouldn't they also base there decision on a couple of opinions from different sources. Absolutely they should , but they don't. I see it all the time with homeowners making un informed decisions.
Louis Agudo |
Louis;
They are too busy on their on trend of activities and don't have a clue to begin with, and then wonder why it is expensive or they got a shabby job after it is done. Marcel |
| Shingle Overhang | Skip Erwin | Exterior Inspections | 0 | 10/5/07 7:32 PM |
| Shingle siding | sfalvey | Exterior Inspections | 11 | 6/13/07 9:36 PM |
| Wooden shingle siding discoloration | wdecker | Exterior Inspections | 4 | 3/26/07 12:07 PM |
| Edging over shingle | rfarnum | Exterior Inspections | 26 | 1/23/07 6:55 AM |
| Asphalt shingle overhang at drip edge | jcampbell | Exterior Inspections | 8 | 11/10/06 8:48 PM |
