Old 2/25/10, 8:04 PM
chardin chardin is offline
Default Shingle tears
I checked a roof for a homeowner that had a roof put on about 5 years ago. The shingles are tearing. The front of the house has the proper staggering of the shingles but the back side of the house doesn't. The shingles on the back side were laid w/ a full shingle and the next course w/ a 6 1/2" offset, then the next course was a full shingle again. This leaves the shingles ends in the same position every other course. I know the offset of the shingles is not correct but the shingles are tearing on both the front and back of the house. Anybody know what could cause this?
Good ventilation. 7/16" decking on 2' centers.
Need a home inspection in Utah? Check out InterNACHI's listing of Utah certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/25/10, 8:10 PM
jkiser's Avatar
jkiser jkiser is offline
Default Re: Shingle tears
Not sure where you are located, but could they have been some strong storms and possible hail in the last 5 years ?
Old 2/25/10, 8:19 PM
Mark Thorman Mark Thorman is offline
Unmoderated Guest
Please Note: Mark Thorman is a non-member guest and is in no way affiliated with InterNACHI or its members.
Check out this web site.
http://www.certainteedshinglesettlement.com/
Old 2/25/10, 8:21 PM
I am located in southern Indiana. We haven't had any hail for a long time. We did have some hard wind for a day from a hurricane a couple of years ago. I looks to me like the shingle has been pulled from a lateral force. Contractor says bad shingles but I did see this on a house a couple of years ago. The realtor said at that time the shingle was installed incorrectly.
Old 2/25/10, 8:23 PM
They are Owens Corning dimensionsal shingles.
Old 2/25/10, 8:28 PM
jkiser's Avatar
Originally Posted by Mark Thorman View Post
Those are not organic shingles. they have fiberglass base
Old 2/25/10, 8:29 PM
http://www.inspectapedia.com/roof/SplittingShingles.htm
http://inspectapedia.com/roof/shingles.htm
http://www.nachi.org/forum/f16/asphalt-shingle-cracking-1129/
http://www.lawyersandsettlements.com/features/certainteed-shingles.html
Larry Kage, CMI
231 929 3525
Old 2/25/10, 8:40 PM
Yes, they are fiberglass based.
Old 2/25/10, 8:48 PM
jkiser's Avatar
To me it looks more like tears than splits or cracks. also looks in spots to have granules missing like hail damage just IMO
Old 2/25/10, 8:51 PM
Thanks for your help, I apprectiate it.
Old 2/25/10, 10:14 PM
Matthew K. Klein's Avatar
Matthew K. Klein Matthew K. Klein is offline
Notice that the tears are where the underlying shingles butt up against each other? I am thinking that it does have to with expansion and contraction of the shingles. If the upper shingle glues down to the underlying shingles when they are expanded and then the shingles shrink when they cool, I can see a tear resulting.
Matthew Klein, P.E., M.B.A.
Criterium Engineers
PO Box 181503
Cincinnati, OH 45018-1503
Phone: 513-474-9600
FAX: 888-747-0427
E-mail: Criterium-Cincinnati@fuse.net
Website: www.Criterium-Cincinnati.com
Old 2/26/10, 9:38 AM
Hail does not do that type of damage..........and expansion and contraction.......uh.....no.
Without physically being there I would simply say that the shingle did not seal at those particular locations, add to the admitted storm / hurricanes..........that is likely culprit.
Simply report that several shingles are damaged and need to be replaced or repaired.
Old 2/26/10, 1:02 PM
dbelmont dbelmont is offline
Send a message via Yahoo to dbelmont
Please Note: dbelmont is a non-member guest and is in no way affiliated with InterNACHI or its members.
Shingles failed to seal. That could be an installation issue or a shingle quality issue. Regardless it left them vulnerable to being bent with a good wind and torn.
Report as damaged and in need of repair to prevent further damage and water entry.
Old 2/26/10, 8:24 PM
Chuck Evans's Avatar
I think James on the right track. Looks like the underlying shingle lifted in the wind and tore the tab of the shingle above. Were these shingles high nailed?
Chuck Evans (TREC #7657)
Houston Home Inspector
Houston, TX
Shooting to begin on comprehensive new roofing courses kshepard Inspection Education & Training 4 11/7/09 3:59 PM
Shingle siding sfalvey Exterior Inspections 11 6/13/07 9:36 PM
Wooden shingle siding discoloration wdecker Exterior Inspections 4 3/26/07 12:07 PM
Edging over shingle rfarnum Exterior Inspections 26 1/23/07 6:55 AM
Shingle defect? gschatz Exterior Inspections 9 5/12/06 5:57 PM
