Go Back   InterNACHI Message Board > Specific Inspection Topics > Exterior
Exterior Contains discussions about the exterior portion of a home inspection. This includes roofs, gutters, downspouts, decks, patios, windows, et cetera.
Old 6/16/09, 11:36 PM
Joe Funderburk, CMI's Avatar
Default Shingles over or under flashing?
This is a skylight. Any issues here roofer guys? Does everyone agree that the shingles cover the flashing instead of the flashing covering the shingles?
shingles-over-under-flashing-061609-044.jpg shingles-over-under-flashing-061609-042.jpg
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Find an InterNACHI certified Illinois Home Inspector (and anywhere else in North America)
Old 6/16/09, 11:38 PM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Shingles over or under flashing?
Nice light tube and nice leak to follow.
Old 6/16/09, 11:43 PM
Ian A. Niquette's Avatar
Ian A. Niquette Ian A. Niquette is offline
Send a message via ICQ to iniquette
I usually see them with the shingles covering down to the bottom of the tube and the rest over the shingles with no exposed nails. I don't like that one at all.
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Active Rain Network
What we've got here is......failure......to communicate.....
Old 6/17/09, 1:39 AM
jkogel jkogel is offline
Looks like an afterthought, add-on. Needs more flashing, more goop.
Old 6/17/09, 10:08 AM
It does look like it was added after the roof was shingled but more tar is not the answer for a long term fix,...correct installation is.
Larry Kage
231 929 3525
Professional Inspector and Infrared Thermographer serving the Traverse City, Michigan area and beyond.
ITC/FLIR CERTIFIED BUILDING SCIENCES THERMOGRAPHER
ITC/FLIR CERTIFIED LEVEL 1 THERMOGRAPHER
Old 6/17/09, 10:49 AM
David P. Valley's Avatar
Originally Posted by jfunderburk View Post
This is a skylight. Any issues here roofer guys? Shouldn't the shingles cover the flashing instead of the flashing covering the shingles?
Attachment 29328 Attachment 29332
Joe,
Same type of flashing here, but these guys went with 1 additional course of shingles....
which is still wrong.
With that type of flat edge flashing, the shingles should have overlapped 2 additional courses, until they reached the lower edge of the flashing or at least past the penetration of the roof sheathing.
This is what I like to see for square flashing....
There is a better circular flashing....
Old 6/17/09, 10:55 AM
Erby Crofutt's Avatar
Erby Crofutt Erby Crofutt is offline
Obivously installed and sealed in place in the winter when the material was cold.
Expansion, but nailed in place at the bottom, caused it to bow up.
I usually see this with shingls up to the tube, tube flasnhing installed over the lower shingles, and then the top half covered with shingles.
Just like metal flues and vent foot flashings.
Erby Crofutt
B4U Close Home Inspections
Georgetown, Kentucky
KY Lic# HI-2041
www.b4uclose.com
http://www.kentuckyradon.com
Kentucky Home Inspections
Kentucky Home Inspectors
NACHI02090301
Read my Active Rain Blog here: Erby, The Central Kentucky Home Inspector
Join Active Rain HERE and I'll get some points for your participation. Please! I did ask nice!
Old 6/17/09, 12:35 PM
As already said, overlapping shingles should have extended 2 more courses and the fasteners hidden beneath the lowest course.
EXPERT WITNESS
Director of Green Building
Director for International Development
(303) 717-8940
(303) 258-8289
Old 6/17/09, 2:51 PM
Bruce A. King's Avatar
Exposed fasteners is ok as long as the heads are caulked, same as with plumbing vent boots.
Shingles should be down to the lower edge of the round part as shown in these links
http://www.lowes.com/lowes/lkn?actio...rSkylight.html
scroll down for picture:
http://www.solatube.com/homeowner/brightenup.php
www.BAKingHomeInspections.com
704 301-3207
Old 6/17/09, 5:17 PM
Acceptable however not great.....would I write it up......No.
My roofing crew will nail the top and middle edges of the vent boots and cover same with shingles (they also seal under the vent boot as well)......in some case we will nail the bottom as well and caulk same.....usually with steeper roofs where the vent pipe is putting additional pressure on the bottom flange which requires fastening same down.......hope that makes sense.
Jeff
Old 6/19/09, 5:13 PM
Frank Albert's Avatar
Frank Albert Frank Albert is offline
Please Note: Frank Albert is a non-member guest and is in no way affiliated with InterNACHI or its members.
The No-Caulk method. Old school.
http://www.albertsroofing.com/Power%...stallation.htm
Old 6/19/09, 5:53 PM
Originally Posted by Frank Albert View Post
Thank you...as it should be.
Larry Kage
231 929 3525
Old 6/22/09, 8:55 PM
William J. Decker's Avatar
Roof penetrations should ONLY be installed BEFORE the roof covering is installed.
If you are adding new penetrations, they MUST be done by a professional (and in Illinois, state licensed) roofer so as to get the flashing correct.
Rule # 101, sub a): Roof dope is NOT flashing.
Hope this helps'
Will Decker, CMI
ILL License # 450.0002240
Decker Home Services, LLC
Office: (847) 676-8393
Cell: (847) 609-2345
Home: (847) 673-2702
wjd@DeckerHomeServices.com
www.DeckerHomeServices.com
Old 6/27/09, 4:41 PM
Roofer repaired it exactly like I thought he would.
Joe Funderburk, CMI
Old 6/28/09, 8:41 AM
Attachment 29637
Joe,
You told your clients that the 10 cent upgrade was improper, right?
Comp shingles: step flashing VS continuous kshepard Exterior 24 6/27/09 12:33 AM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior 6 10/13/07 9:10 AM
3 tab shingles curling ccbrands1 Exterior 8 1/29/07 6:25 PM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
