Old 4/15/06, 7:50 AM
gporter's Avatar
gporter gporter is offline
Default How should I write this
Gary Porter
GLP's Home and Mold Inspections
321-239-0621
Certified Commercial Mold Inspector
Serving Orlando, Kissimmee, Winter Park, Winter Springs, Oviedo, Titusville, Celebration, Harmony, Avalon, Windermere, Deltona, Debary, Sanford
Orange County, Seminole County, Volusia County, Osceola County
www.homeandmoldinspections.com
Old 4/15/06, 8:51 AM
David P. Valley's Avatar
Default Re: How should I write this
Is this Stucco?
What's that brown material below the Stucco?
Old 4/15/06, 9:40 AM
ccarrington's Avatar
ccarrington ccarrington is offline
It does appear to have been damaged previously, and repaired; and now again needing repair and the small brown patches look like rust on a metal window frame, though it could be mold? What is above this window? Could there be a leak in the roof above this, and water is coming down to sit above the lintel, and soaking through at that point?
Old 4/15/06, 11:32 AM
gporter's Avatar
Painted block.
Gary Porter
321-239-0621
Old 4/15/06, 3:17 PM
If that's block, then where's the steel lintel?
Old 4/15/06, 3:31 PM
gporter's Avatar
It was built in the early 50's
Gary Porter
321-239-0621
Old 4/15/06, 3:42 PM
Doesn't matter, there's obvious signs of settling and a lintel installation is imminent.
Old 4/15/06, 4:10 PM
Gary;
It appears that the exterior stucco has been patched in the past for the same problem.
The wood trim on the exterior shows an exteme amout of water infiltration by the decaying cracks in it, and also could be hiding the steel lintel.
The wood trim is holding water between the stucco, and rust on the what appears to be jealousy windows came from the steel lintel that we can not see.
I would recommend that the wood trim be removed and the steel lintel, if it exist, be caulked and the stucco repaired one more time.
Hopes this helps.
Marcel
Old 4/15/06, 4:20 PM
gporter's Avatar
Thanks a bunch
Gary Porter
321-239-0621
Old 4/15/06, 4:21 PM
David A. Andersen's Avatar
Cracking is indicative of moisture intrusion. Past repairs have reoccurred, indicating an active situation. Inspection by a stucco / EIFS recommended.
Old 4/15/06, 9:36 PM
Carl A. Brown's Avatar
It looks like they put some sort of stucco / dash finish right over the block.
Old 4/15/06, 9:39 PM
Jay Moge's Avatar
Jay Moge Jay Moge is offline
Originally Posted by mcyr
Gary;
Hopes this helps.
Marcel
I coucure with you Marcel. i guess we still think alike on most things. usualy if you've posted, i don't need to 'cuz you already said it.
AHJ's opinion differs from code...how would you write it up? jhugenroth Plumbing Inspections 9 8/31/09 8:04 PM
How would you write This gporter General Inspection Discussion 12 9/24/07 2:38 PM
Tidbits from the ASHI Message Board jbushart Miscellaneous Discussion for Inspectors 126 4/27/07 11:05 AM
Write It up or not? thejnicki Electrical Inspections 5 8/7/06 3:49 PM
How should I write this gporter Inspecting HVAC Systems 8 6/29/06 3:27 PM
