Old 2/24/10, 6:35 PM
David C. Macy's Avatar
Default sidewall flashing
How would you report on this sidewall flashing installation?
Looking for report verbiage and an illustration if you have it.
I want to compare my verbiage and reporting with others.
ID:	35196   sidewall-flashing-154910-017-small-.jpg.jpg
Need a home inspection in Hawaii? Check out InterNACHI's listing of Hawaii certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/24/10, 6:42 PM
Michael Larson's Avatar
Default Re: sidewall flashing
David,
Use a narrative and illustration of proper step flashing and you should be good to go.
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
Never underestimate the difficulty of changing false beliefs by facts.
- Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
and
Minnesota Home Inspector
Old 2/24/10, 6:45 PM
how this illustration?
I was looking on the Nachi library but did not see a good one.
Old 2/24/10, 6:48 PM
AOK!
Michael Larson
Hudson, WI
InspectraPro
and
Old 2/25/10, 9:55 AM
Frank Albert's Avatar
Frank Albert Frank Albert is offline
Please Note: Frank Albert is a non-member guest and is in no way affiliated with InterNACHI or its members.
Haven't got enough coffee in me yet to handle this, this morning.
"The roof looks newish.
The flashing was done wrong. So wrong it raises many flags about the rest of the installation, including nail placement.
The caulk on top of the flashing indicates it has leaked since the new roof was installed.
The roof should now be inspected by a qualified roofer and re-evaluated for repairs, or replacement."
Are the vents done correctly? 50/50% exposed/hidden?
Any valleys? Tips clipped off?
I bet if you looked around, you'd see slight bulges of high nails that point out where leaks will occur in the next 12 months or less.
Old 2/25/10, 10:01 AM
How is the eave done? Started cut from 3-tabs so sealer is on the bottom edge to prevent blow-offs? Or just 3-tab over 3-tabs?
Old 2/25/10, 10:14 AM
Frank
I am a green tea guy and will start drinking them soon.
Roof was a tear off, only one shingle had nail penetration through the shingle, valley was closed and only a small portion has a valley, no chimney. Eaves looked good with edge flashing.
Just seemed like the side wall flashing was done wrong and the sealant at the sidewall looked like a past leak, could not access lower attic and may be going back tomorrow.
The roof decking had stains at all the nail penetrations as some dolt painted all the soffit openings when the painted the metal siding.
Flashing on Shed type roof rross2 Exterior Inspections 7 2/21/10 12:26 AM
Ledger Board Flashing jevans Exterior Inspections 15 7/2/09 11:42 PM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 9:10 AM
Graphic needed for flashing under stone work lfoster Exterior Inspections 8 8/2/07 11:54 PM
no flashing; no inspection Leanne Jowers Exterior Inspections 97 5/9/07 1:11 PM
