Old 8/31/09, 8:29 PM
John Harrison's Avatar
John Harrison John Harrison is online now
Default Siding installation
On this inspection I noticed that the siding is placed over the service mast. Holes are punched throught the siding to make openings for the electric lines and other items.
I am not completely sure how to write this up as I have never seen something like this done before.
I told the client that it should be redone properly or at least some form of a sealant to close up the holes to avoid rain from entering behind the siding and causing further damage.
Any thoughts or comments??
Performing Home Inspections in Council Bluffs, Missouri Valley, Glenwood, and surrounding areas
Active Rain Member
Find an InterNACHI certified Alabama Home Inspector (and anywhere else in North America)
Old 8/31/09, 9:12 PM
Default Re: Siding installation
The vinyl is a joke. Is that a new window? It sure looks closer than 3'
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 8/31/09, 10:15 PM
Bob Elliott's Avatar
Closest is the phone lines Bruce.
Old 9/1/09, 6:35 AM
Bob, I understand that, but how does that make a differance on the service being within 3 feet of the window?
Bruce M. Graham III
352 871 8989
NACHI05091592
ICC 5268478
Old 9/1/09, 8:31 AM
I have so far in my report I have basically stated:
siding in installed incorrectly and should be corrected.
Service lines are too close to an operable window.
Unable to inspect condition of electric meter, service mast, or any connections associated with the two.
Active Rain Member
Old 9/1/09, 10:43 AM
The electric service attachment may not be within 3 feet but I can see where you might have thought the phone line attachment was as it is closer.
The conductors appear to be more accessible from the upper window which often is not counted.
In other words it does not appear to be a big concern.
Now the meter should have 2 inches clearance at the sides so that might be more of an issue though I would mention the fact mast attachment brackets are not viewable and the siding has a wavy appearance due to the non standard siding work .
I doubt siding is meant to curve in that manner and I would think it will have a tendency to separate or crack over time.
Old 9/1/09, 12:31 PM
Something just don't add up.
How did they bury the mast riser and the meter box and yet the window is on the same plane as the siding?
Did they fur out the outside walls and then install the new window. ???
What did the bottom of the wall look like at the foundation and box sill?
Old 9/1/09, 1:53 PM
Hi Marcel
If you look close you can see it bulging around the mast and looking non-professional .
It will most likely pull away as it is not fastened correctly.
Old 9/1/09, 2:00 PM
I see the bulge Bob, but the typical meter box is 3-1/2" to 4" thick, and the window is not buried by the same amount.
Old 9/1/09, 2:31 PM
The bottom sill looked normal as I walked around.
This inspection is a 2 part one for a move in certified. I will either go back and check on this more, or cover it during the next visit after the client has his contractors on site.
Active Rain Member
Old 9/1/09, 2:32 PM
Marcel I think that is the framing around the box (which they should have done for the mast too).
Old 9/1/09, 3:09 PM
Standard 100 amp meter on top of vinyl siding.
When vinyl siding is done, they do what is called "Float the Meter"
The siding is done and reinstalled after the siding is done.
The Utility Company does that I believe at no cost.
Power is not disrupted, but a couple of minutes.
Look at the relationship of the face of the meter box and the window.
They are not in the same plane.
Hope this helps.
Old 9/1/09, 4:40 PM
Yep
They should have done that.
Old 9/2/09, 9:08 AM
David P. OKeefe's Avatar
David P. OKeefe David P. OKeefe is offline
Looks like it was done by the homeowner and a couple of his buddies in between cans of Bud. They probable didn't know utility co. would remove meter and replace after siding was put up.
David
InterNACHI #08051301
NYS Lic. #16000038229
NYS DEC Cert # T4865884
518-505-8305
HouseAbout Home Inspections
HouseAbout on Facebook
NY Capital Region Chapter InterNACHI
Old 9/2/09, 9:11 AM
They don't offer that service around here.
One must hire/pay an electrician to do that.
Nonetheless, it should have been done.
Larry Kage, CMI
231 929 3525
Reckless comments incriminate sellers in home siding suit gromicko Exterior Inspections 2 2/26/08 10:44 PM
Siding installation and electrical service equipment jtedesco1 Exterior Inspections 1 12/16/07 4:59 PM
Vinyl siding installation guide badair Exterior Inspections 18 3/27/07 5:38 PM
