Old 6/4/08, 2:29 AM
Holm Byers Holm Byers is offline
Please Note: Holm Byers is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Siding installation question
Dear Experts,
I am planning to buy a house, new construction. I had it inspected by a professional inspector. One of the bothersome things he found is regarding the siding.
The edged of some of the siding panels got separated perhaps because of too much nailing force. Attached is the picture of the siding.
Is this OK? Will this void warranty for the siding? Can you please let me know of this is something that need to be replaced completely.
thanks
Holm Byer.
PS: I value your opinion very much since y'all saved my skin in the past wrt inspection. Great Job!!
siding-installation-question-img_0309compresd.jpg   siding-installation-question-img_0308comprsd.jpg
Old 6/4/08, 1:33 PM
Ron E. Perkerewicz Ron E. Perkerewicz is offline
Default Re: Siding installation question
check the manufactures warranty and installation sheet for the acceptable damage that can be done without voiding the warranty. If it won't meet their standard it should be replaced.
Old 6/6/08, 3:58 PM
Thanks Ron,
I downloaded the warranty information from a couple of manufacturer and they both void warranty on faulty installation. But none of them tell whether the kind of damage I showed in the pictures is OK or not. Their instruction manuals specify the nailing methods and the contractor seems to have done that OK. Caulking, I can check and make sure he does that. Nails driven deeply are OK too as per manufacturers as long as the nail holes are caulked and painted over properly flush with the rest of the surface.
My main concern is the edges being separated into layers when nails were driven. If you look the 2nd photo you will see that he edge is frayed (term may not be correct) as shown in the blue rectangle.
I wanted to check if thats OK with Nachi members who see worse disasters every day .
Your help and opinion is greatly appreciated
Old 6/6/08, 4:21 PM
bdoles2's Avatar
bdoles2 bdoles2 is offline
How did the rest of the house look? Where there similiar problem areas? If there are only a few locations with the seperation, and it was my house I would use the proper caulk at the bottom edge of the siding and at any other exopsed area(nail heads). All to prevent any further weather intrusion.
Just my opinion. If the problem of seperation is only minor, just caulk it. If you try to deal with the manufacturer and their warranty, your going to get a huge headache and probably not get any new siding.
Good luck!
Old 6/6/08, 4:31 PM
Doug Edwards,  CMI's Avatar
Just curious; who is the manufacturer of the product? It looks similar to Hardi board. I have never seen that particular product locally.
Old 6/6/08, 4:40 PM
Hi Doug and Brian,
This is a new construction. I haven't found out whether its Hardiboard or not. I remember seeing hardie labels around during construction. The construction is finished waiting final walkthru.
Home inspector observed it and advised to check if this voids warranty. So I wanted to see if this usually happens at installation. Rest of the house is well done. The problem shown is also present in a couple of areas. Bigger areas of siding like the back wall look good.
So I am wondering if this something to loose sleep over (literally) with closing data approaching.
thank you
Old 6/6/08, 4:49 PM
ROBERT W. NEWLAND, JR.'s Avatar
ROBERT W. NEWLAND, JR. ROBERT W. NEWLAND, JR. is offline
Sorry I haven't had time to read this but it may help. It was posted here a while back. Good Luck!http://www.jameshardie.com/pdf/insta...lank_north.pdf
Robert Newland
Tyrone, GA 30290
NACHI05101290
http://www.CertifiedHI.com
http://www.HomeInspectorTyroneGa.com
Home Inspection Reports Powered by:
HomeGauge eServices
Old 6/6/08, 4:50 PM
thank you
It looks kind of fiberboard-ish, but whatever it is, keep it sealed up to prevent water entry but don't loose sleep over it.
Larry Kage, CMI
231 929 3525
Old 6/6/08, 4:52 PM
Don't think my link above worked. Try thishttp://www.jameshardie.com/pdf/install/install_plank_north.pdf
Robert Newland
Tyrone, GA 30290
NACHI05101290
HomeGauge eServices
Old 6/6/08, 4:54 PM
I'm using a remote computer and my edit fuction is not working. One more time. http://www.jameshardie.com/pdf/insta...lank_north.pdf
Robert Newland
Tyrone, GA 30290
NACHI05101290
HomeGauge eServices
Old 6/6/08, 5:17 PM
Thumbs up Re: Siding installation question
Thanks for all the valuable advise. I am actually in the south, the great state of Texas. So I downloaded the instruction sheet for the southern regions, before I even started posting here. It actually helped to some extent to relieve my concern.
I am from technical background but not as informed as you all are on this board in house matters. I was going to get the cracks and joints caulked and painted and call it done. But if it was something that voids warranty I wanted to know before closing on the house so that I can get it repaired/replaced.
I will get the information about the manufacturers and the remedies made to fix it when done.
thanks
Siding identification Timothy T. Shaffer Exterior Inspections 29 4/5/09 11:04 AM
Question about improper installation cbell1 Exterior Inspections 3 10/24/07 10:13 PM
Concrete Porch abutting siding scosta Exterior Inspections 44 9/8/07 6:25 PM
Asbestos jlybolt Exterior Inspections 38 7/17/07 2:13 AM
Common Defects List by Age of House trausch Inspection Education & Training 10 6/12/06 5:52 AM
