Old 11/17/09, 3:46 PM
David P. Valley's Avatar
Default Siding Stains
Hi Guys,
There is a mysterious stain developing at this (and other inspections I've performed) vinyl siding at the seams. I've seen it on other houses but I never pay attention to it.
I see it so much now I'm simply curious.....Can someone tell me how/why this is occurring?
Could it be missing TYVEK on the underside?
Find an InterNACHI certified Maine Home Inspector (and anywhere else in North America)
Old 11/17/09, 4:09 PM
mnahrgang's Avatar
Default Re: Siding Stains
You could peek under a seam and check...
My guess is that when the wind blows, the siding flexes and bows. As it does so, air rushes in underneath it at the seam. When it returns back to normal shape, the air is blown back out the seam taking any stirred up dust with it. It sticks to any moisture on the siding, and when it dries it leaves this pattern.
For the record I do not know this is happening, I am just positing it as a theory.
Mark Nahrgang
www.HeyMark.info
Old 11/17/09, 4:33 PM
Ya, it was too high to get to in order to pull this siding away.
Old 11/17/09, 5:18 PM
Michael Roberson's Avatar
Michael Roberson Michael Roberson is offline
To add to Marks theory, two of them are in the same row, and facing opposite directions. Another reason to lap your siding all the same direction. Does this side get any sun? and we are looking at a gable, right?
Old 11/17/09, 5:40 PM
Michael,
Yes, Gable end.
This is a manufactured home, stacked and structurally tied together if that helps.
Old 11/17/09, 6:21 PM
That explains the short piece in the middle. I have seen countless homes (including my own) put together quickly. It is standard practice to only install house wrap on the exterior wall, and not the upper gable. You may have nailed it with the lack of house wrap. If it should happen to blow off in transport, it sometimes doesn't get replaced. (same with insulation as far as that goes)
Old 11/17/09, 8:10 PM
James E. Braun, CMI's Avatar
Most manufactured homes that I see do not have house wrap. Sad but true.
Old 11/18/09, 6:37 AM
Uh-ha...then I probably have a manufactured home with no house wrap.
I wonder if this staining happened during transport? That could be the case, because there were several areas where the siding and vinyl trim had to be slid into place to cover exposed sheathing.
Old 11/18/09, 9:45 AM
Dale Duffy's Avatar
Another (soon to be) MULCH home...incredible---
What they do to save a buck-------------------
Red/Brown Stains on Cedar Siding dvalley Exterior Inspections 18 3/20/11 7:35 PM
warped vinyl siding sgreen2 Exterior Inspections 4 10/28/09 7:36 AM
Reckless comments incriminate sellers in home siding suit gromicko Exterior Inspections 2 2/26/08 11:44 PM
