Upper half of 1991 home had this type of wall covering with damage in a couple areas. I wonder if this might be EIFS however typically the foam is attached to OSB using approved adhesive followed by cement type base coat etc. However when I was in the attic the wall structure was not OSB and had stickers that stated "Siding Panels."
Vince Santos
StepByStep Home Services LC (734) 748-9584 Providing Home Inspection Services to Southeast Michigan ITA Trained and Certified Last edited by vsantos; 1/29/09 at 3:18 PM.. |
Hard for me to tell from that picture but there was a 4x8 siding product kind of a Masonite product as I recall that was used about that time,...usually finished off with a lot of wood trim to give a tudor look,.....terrible product if misture got to it in any way...had to keep it well caulked and painted or you had lots of trouble with it swelling and crumbling...jim
It looks like this. Hardboard.
http://www.stucconews.net/questions/question303.html http://www.topproducerwebsite.com/us...ct%20sheet.pdf page 5 . Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
I believe it is Hardboard siding. What verbiage would you use on the report?
Vince Santos
StepByStep Home Services LC (734) 748-9584 Providing Home Inspection Services to Southeast Michigan ITA Trained and Certified |
you go first
Siding throughout the exterior appears to be Masonite Hard Board type which is known to be problematic particularly when not properly maintained. Siding shows signs of deterioration in one or more areas. Recommend evaluation and repairs/replacement by a qualified contractor prior to close.
Your turn. Vince Santos
Can I? Can I? Yours is probably better, but I'll start.
Hardboard siding is not real wood siding and is a high maintenance siding. It must be continuously monitored. All seams be must remain sealed and paint must be applied periodically, especially the lower courses at ground and other contact levels. Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
Oops, Vince was posting when I was typing.
Hey I appreciate the help.
Vince Santos
Staccato board though I am not sure of the spelling.
Cheap imitation stucco look alike siding. "I create controversy whether they like it or not" |
Lets make the spelling be stuccato.
No problem, I'm sure you would help. I've ran across different styles of hardboard a few times. Usually on homes built in the 70's
Is that the Italian version?
I am not at liberty to discuss that here! "I create controversy whether they like it or not" |
I posted this same question on this board about a year or two ago.
This is the verbiage I kept. I call it stuccato Board, it is made out of a masonite material with the stucco look. It should be kept painted and holes or nail pops should be sealed, it will suck water and swell. http://www.nachi.org/forum/f2/siding...53/index2.html My post is #24. |
| What type of siding | rchorey | Exterior Inspections | 10 | 7/14/08 9:14 PM |
| Reckless comments incriminate sellers in home siding suit | gromicko | Exterior Inspections | 2 | 2/26/08 10:44 PM |
| Commercial Electrical Inspections | jtedesco1 | Commercial Inspections | 29 | 1/12/08 5:03 AM |
| What Type Of Siding Is This? | gmoore2 | Exterior Inspections | 13 | 3/30/07 1:18 PM |
