Old 4/24/11, 7:00 PM
Bruce M. Sutherland Bruce M. Sutherland is offline
Default Siding warped
Any ideas what may cause this? It's on the north and west side of home. Home was built approx 8 years ago. Is it bad install?
Need a home inspection in Minnesota? Check out InterNACHI's listing of Minnesota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/24/11, 9:04 PM
Ken Brittain Ken Brittain is offline
Please Note: Ken Brittain is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Siding warped
Improper installation, the siding was nailed tight and not allowed to "hang" loose, also could of been cut too long and not given enough room to expand on the ends.
Old 4/24/11, 9:56 PM
Banned
3 possible answers:
1) buckled sheathing from moisture. Consulted on this phenomenon in Jan/Feb 1987-8 in New Brunswick, Canada. Contractor had poured a bunch of foundations in Oct/Nov/Dec, had the bungalows roof tight with windows/doors and sidng on. In Jan, plumbing/elect/drywall crews were working indoors using propane heaters that created a lot of moisture that warped the plywood/OSB sheathing. Was called in by the siding supplier/installer as his product/crews were being blamed. For some reason, 1 of the houses had been sheathed in boards and suffered no buckling. In the end the builkder went out of business and the houses went to auction with most being sold for $25-30,000, about 1/2 the normal market price
2) Bowed studs
3) Nails installed too tightly, not allowing siding to slide freely in the nailing slots
Old 4/24/11, 11:05 PM
Jeffrey R. Jonas's Avatar
Agree.
Old 4/24/11, 11:06 PM
Christopher Currins's Avatar
Nailed, or stapled, too tight.
Christopher Currins
Certified, Licensed
Old 4/25/11, 7:32 AM
Thanks for the info everyone. I appreciate it.
Old 4/25/11, 8:19 AM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is offline
The sheathing is on the north side and never dried correctly.
1/8 inch gaps at each installed sheathing was not applied and may have created the problem.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
warped vinyl siding sgreen2 Exterior Inspections 4 10/28/09 6:36 AM
Damaged (warped) Vinyl Siding krichardson Exterior Inspections 2 10/24/09 1:16 PM
warped siding (posted by Mindy smith) AskNACHI.org AskNACHI.org Inspection Questions Forum 2 3/11/08 10:09 PM
Reckless comments incriminate sellers in home siding suit gromicko Exterior Inspections 2 2/26/08 10:44 PM
