What is the purpose of the 2/10 requirement for chimney height. I've asked my fire cheif and he wasn't sure though we have a couple of guesses.
| Find an InterNACHI certified Washington Home Inspector (and anywhere else in North America) |
Back drafting
Nick Gromicko, Certified Master Inspector Find a Home Inspector "Just as iron sharpens iron, one man sharpens another." Proverbs 27:17 Last edited by gromicko; 12/9/09 at 8:04 PM.. |
Thanks guy's. I actually thought it was to prevent smoke from entering the attic through the roof vents.
Your fire chief should also known the difference between ionization and photoelectric technology in smoke detector's and the purpose of CO detectors. Unfortunately most don't... Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
Tim |
To put it simply...
Wind blowing across the chimney opening helps draw exhaust gasses from the exhaust flue. If you were to look at it on a really small scale, you'd see that the wind creates a vacuum across the top of the chimney. This helps to suck gasses out of the chimney. If the roof shape interrupts the flow of the wind, it reduces the pull that the wind has on exhaust gasses. The chimney needs to stick up high enough that the wind blows across its opening. If it's too low... it won't work well. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
[quote=sschroetke;591859]What is the purpose of the 2/10 requirement for chimney height. [quote]
The 2/10 rule is a code minimum and make not work in some extreme sitiuations such as when a house is surrounded by higher coniferous trees and the chimney is in the lee of the prevailing winter winds coming over the trees and then moving downward. Another situation is when the 2/10 rule is met and the chimney exits a low roof in the lee of a higher roof's prevailing winds. |
| Got a letter from ASHI's President today. | gromicko | General Inspection Discussion | 55 | 12/12/10 11:51 PM |
| Chimney venting | mmerino | Inspecting HVAC Systems | 17 | 7/8/09 12:40 AM |
| Chimney Question | Rick Vollmer | Exterior Inspections | 4 | 6/21/09 8:07 AM |
