Old 1/14/08, 1:04 PM
msylvester's Avatar
msylvester msylvester is offline
Send a message via AIM to msylvester
Default Sink Hole
Here is a brand new home that my client just moved into. We did a final punch list inspection on the home and found many issues but this one just appeared in the last week or so.
WOW!
Either bad backfill or worse a cracked sewer line...
sink-hole-img_3088.jpg   sink-hole-img_3089.jpg   sink-hole-img_3090.jpg   sink-hole-img_3092.jpg   sink-hole-img_3094.jpg
Mark Sylvester
P.I. Home Inspection Services
www.pihomeinspection.com
mark@pihomeinspection.com
Old 1/14/08, 1:12 PM
Default Re: Sink Hole
WOW!
I thought sink holes were just in Florida!
Wow, is that where they excavated for the sewer line or water line?
I guess someone is going to remove the carpet lawn and start over.
These site Contractors, they are all alike, ha. ha.
Hope they go good for your Client.
Marcel
Joseph Hagarty,  CMI's Avatar
Poor backfill conditions generally.
Is this the area of the Water Supply and/or Sanitary Sewer run? Quite a common occurrence from what I see.
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 1/14/08, 1:17 PM
msylvester's Avatar
This is defiantly where the sewer line runs. I told him to have the builder pay for a video scan of the line now just in case. Most likely a backfill issue.
At least I hope for my clients sake.
Mark Sylvester
Old 1/14/08, 1:41 PM
Most likely backfill as the depression appears to be uniform accross the lawn.
If the sinkhole was in a single / isolated area, I would tend to believe a line failure.
Are Exterior Drains Cast or PVC in your area?
Joseph P. Hagarty
Phone: 610-399-3675
Old 1/14/08, 2:18 PM
msylvester's Avatar
In this case it is cast coming out of the home and into PVC somewhere outside the foundation wall. I usually see about 6' of cast coming out of the foundation into PVC. On newer homes of course.
Mark Sylvester
Old 1/16/08, 8:32 AM
Banned
Interesting that cast iron pipe is still being used in your area. Haven't seen new used here for 30+ years. It's all ABS ( in house) and PVC to street.
Old 1/16/08, 8:53 AM
msylvester's Avatar
They only use it in the section that comes through the foundation.
Mark Sylvester
Old 1/16/08, 9:01 AM
ldapkus ldapkus is offline
I've seen cast iron and copper in new homes built in Cook County.
Old 1/16/08, 9:04 AM
msylvester's Avatar
Ditto.
Although I don't see copper for waste in new construction. Way to expensive.
Mark Sylvester
Old 1/16/08, 9:16 AM
Banned
I had wondered about that. What's the reasoning?
Old 1/16/08, 10:30 AM
cduphily's Avatar
cduphily cduphily is offline
Please Note: cduphily is a non-member guest and is in no way affiliated with InterNACHI or its members.
Here's one from earlier this year. Poor planning on Gutter runoff and poor fill. Gutters at front and rear corner both terminated in same area.
Old 1/16/08, 10:41 AM
msylvester's Avatar
My friend who works for a backhoe service will tell you it's to keep him employed fixing sheared off waste lines. When they are repaired they use PVC instead of cast. Not sure of the reason as to why they use such a short run.
Mark Sylvester
Composite granite kitchen sink ... good choice? Bill Featherstone Plumbing Inspections 6 1/8/08 11:03 PM
Sink Clog dirtydishes Plumbing Inspections 26 8/27/06 3:48 PM
What's under the sink? jnicholson Plumbing Inspections 3 6/7/06 9:43 PM
Sink Holes May 13th zfackler General Inspection Discussion 0 5/2/06 11:01 AM
