Old 12/30/08, 2:34 PM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Default Size of Roofing Nail???
This was found at today's inspection, this is the size of roofing nail found used to nail down the shingles.
Thank you, for you input in advance. I will show you the roof later.
Old 12/30/08, 3:08 PM
Michael R. Boyett's Avatar
Default Re: Size of Roofing Nail???
Fasteners for asphalt shingles shall be galvanized steel, stainless steel,
aluminum or copper roofing nails, minimum 12 gage [0.105 inch (2.67 mm)]
shank with a minimum 3/8 inch (9.5 mm.) diameter head, ASTM F 1667, of a
length to penetrate through the roofing materials and a minimum of 3/4 inch (19.1
mm) into the roof sheathing. Where the roof sheathing is less than 3/4 inch (19.1
mm) thick, the fasteners shall penetrate through the sheathing. Fasteners must
comply with ASTM F 1667. Staples are not permitted for shingle application
unless specifically noted in the manufacturer's installation instructions on the
shingle package. Use 4 nails for standard installations, 6 for steep slope or high
wind areas.
Excellence in Inspections
Mike Boyett, TREC #7290
mikeb@capcityinspections.com
Capital City Inspections
Austin, Texas
(512) 577-2579
Old 12/30/08, 6:05 PM
Mike,
The nails never penetrated the sheathing.
Old 12/30/08, 6:34 PM
Mitch A. Harris Mitch A. Harris is offline
Buck,
I've seen the short nails used when shingling over an open eave where the bottom of the roof deck shows from below, on the exterior they seemed to hold fine, the rest of the roof was done with 1 1/2" nails.
Old 12/30/08, 6:54 PM
Would you say this roof was nailed correctly?
Old 12/30/08, 7:23 PM
Carl A. Brown's Avatar
What part of town did you find that one in Buck?
How old is it?
Is it a re-roof?
Old 12/30/08, 7:50 PM
Carl,
It is in a rural area, new roof 4 years ago. The big storm Friday night did not help anything.
Old 12/30/08, 7:54 PM
Those winds were something else.
Old 12/30/08, 7:59 PM
Barry Adair's Avatar
Originally Posted by bhartley View Post
Carl,
helped identify shoddy work and earned you a check, see the last part of my signature
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 12/30/08, 8:04 PM
Were those tabs installed properly? It looks like the top layer was brought down on the bottom layer just barely enough to touch the glue strip.
Jeff
Jeff Wicklander
Corwick Home Services
Join my business on Facebook
Old 12/30/08, 8:09 PM
And they probably set their nails too deep with the coil nailer. It looked like the wire was on the nail picture that Buck posted.
Old 12/30/08, 8:19 PM
I think that was just residue from the fiberglass.
Jeff Wicklander
Old 12/30/08, 8:32 PM
bingo! dead-eye
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 12/30/08, 8:46 PM
aaahh, I see it now after a closer look.
Jeff
Jeff Wicklander
Old 12/31/08, 7:02 PM
So it is true what they say!
Size and penetration does matter!!
Yep, The plastic Nail mcyr Structural Inspections 6 3/23/08 10:53 AM
Nail pops at the base of vaulted ceiling-no roof leak kshepard Interior Inspections 32 9/9/07 2:06 PM
Asbestos jlybolt Exterior Inspections 41 7/17/07 1:13 AM
Ice Gaurd membrane dmacy Exterior Inspections 36 6/14/07 12:21 AM
