Old 4/2/08, 4:16 PM
John Evans John Evans is offline
Default Skylight Flashing
Looking for confirmation of incorrect flashing at the bottom (Down Slope) of the skylights. I believe the flashing should extend over the shingle, not below it as shown. Appreciate some input.
[Maryland Home Inspections
www.aimhomeinspection.com
Infraspection Certified Level 1 No. 7801
Old 4/2/08, 5:57 PM
Jeffrey S. Campbell's Avatar
Jeffrey S. Campbell Jeffrey S. Campbell is offline
Send a message via AIM to jcampbell Send a message via MSN to jcampbell Send a message via Yahoo to jcampbell
Default Re: Skylight Flashing
i would agree... let me see if i have something on that...
Jeff Campbell
Campbell Property Inspections
http://www.maineshomeinspector.com
Pittston, Maine
NACHI04013010
Old 4/2/08, 6:13 PM
David P. Valley's Avatar
It appears that the rain water will run right behind the roofing shingle and into the cavity below.
The flashing system on a curb-mounted skylight typically consists of a head flashing, a sill flashing and two pieces of side flashing that run the length of the skylight. The head flashing is slipped under the shingles above the opening. The side flashings are slipped under both the head flashing and the shingles on the side of the unit. The sill flashing goes under the side flashings but is set over the shingles below the skylight. The configuration allows water to run around and off the skylight.
Old 4/2/08, 6:14 PM
rmaday's Avatar
rmaday rmaday is offline
Please Note: rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
nice pics, David
Old 4/2/08, 6:17 PM
I knew david would have the pics...
Jeff Campbell
Pittston, Maine
NACHI04013010
Old 4/2/08, 6:45 PM
David,
Thanks for the confirmation and great illustrations.
John Evans
Old 4/2/08, 10:20 PM
When we used to install them we flashed the sill on top of the shingles but then glued an appropriate piece of shingle on top of the sill flashing to hide it. I can't tell if that is the case in the photo or not.
Larry Kage, CMI
231 929 3525
Old 4/2/08, 10:36 PM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
Here is from Sunday's.
Same triple play and you can see the flashing is over tile on the bottom.
I did not think highly of the kickout however.
ID:	20052[/ATTACH] (looking down.)
Old 4/3/08, 1:14 AM
Russel Ray's Avatar
I did the same, and in the higher-end subdivions here, they still do that, along with shingle-covered valleys. All the ugly metal flashing is, well, ugly.
Old 4/3/08, 1:28 AM
relliott's Avatar
Hey Russ (stalking)
People like bare brick and exposed ducts don't they?
Exposed flashing fits right in.
Old 4/3/08, 1:53 AM
Russel Ray's Avatar
Originally Posted by relliott
Hey Russ (stalking)
Brick?
I've never seen exposed ducts in a residence, only in commercial buildings.
Old 4/3/08, 11:06 AM
relliott's Avatar
In Chicago and most large Cities that is the hot look going on about ten years now.
Warehouses converted to residence.
Just did one yesterday.(loft style)
Old 4/8/08, 4:57 PM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
I've done a couple of condo's where the buyer tells the owner how much of the wharehouse he wants and then co comes in and builds walls (over simplified of course). The big theme is to leave duct, piping, and etc. exposed. Clean them up and paint them. The industrial motif.
Good pics David. I would like to use them as a "this is the way it should be" explanation to client if okay.
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Old 4/8/08, 5:09 PM
No need to ask. Anything I post on the MB is public domain.
Window flashing -- lfoster Exterior Inspections 42 10/28/07 10:47 PM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 9:10 AM
Question about chimney flashing waksell Exterior Inspections 16 6/26/07 1:25 AM
no flashing; no inspection Leanne Jowers Exterior Inspections 97 5/9/07 1:11 PM
Step flashing at vertical wall? jlybolt Exterior Inspections 31 2/12/06 12:40 PM
