Old 10/12/11, 2:32 PM
Joshua L. Frederick Joshua L. Frederick is offline
Default Skylight flashing
What's the purpose of this flashing? Installed properly?
20+ years old & no leaking.
Thanks in advance.
Need a home inspection in District Of Columbia? Check out InterNACHI's listing of District Of Columbia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/12/11, 2:55 PM
Bob Elliott's Avatar
Default Re: Skylight flashing
That should be under the tile.
Old 10/12/11, 3:00 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is offline
Adjustments are designed for a metal roof attachment. No purpose to shed water and only adds strength to the install.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 10/12/11, 3:31 PM
Say again? Not sure exactly what you're saying.
Old 10/12/11, 3:50 PM
KEVIN WOOD's Avatar
Not sure how to make it any clearer. The adjustment is pushed against the metal sheet when the skylight window is installed; it may be sealed but does not need to be. The reason for the adjustment allowance is the difference in installing the metal roof itself.
Marcel I think just put out info on this from ASC Building products.
http://www.ascbp.com/residential/pro...82.html?id=100
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 10/15/11, 2:04 AM
Nick Gromicko's Avatar
The adjustable piece can just be removed in this case.
Find a Home Inspector
Old 10/15/11, 2:19 AM
Duh ,I just took a glance and rushed in it was the flashing.
Old 10/15/11, 12:23 PM
KEVIN WOOD's Avatar
Nick:
The holes in the framing still need to be sealed to prevent moisture into the framing. Make sure all understand this. I did an inspection where they thought they could be removed and left open. The cathedral ceiling was damaged all the way down the wall. This may have been a result of this or it could be the flashing itself. Any area water can get in will get in.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Skylight Flashing pmaggiore Exterior Inspections 4 3/18/11 8:03 AM
Skylight Flashing pmaggiore Electrical Inspections 6 3/15/11 4:11 PM
Skylight flashing jfrederick Exterior Inspections 2 8/26/09 7:24 PM
Skylight Flashing jevans Exterior Inspections 13 4/8/08 4:09 PM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 8:10 AM
