Old 2/8/07, 4:49 PM
gbrasseur's Avatar
gbrasseur gbrasseur is offline
Please Note: gbrasseur is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Sloppy Stucco question
Hi Inspectors,
I plan on calling out the exposed OSB on this siding. I know most of the exposed OSB is underneath, but feel I should call it out because of moisture/insects. What about the exposed metal corner here in the pics?? Any comments or help would be appreciated! Thanks all.
ID:	9011   sloppy-stucco-question-100_3694-small-.jpg.JPG
ID:	9012   sloppy-stucco-question-100_3695-small-.jpg.JPG
ID:	9013   sloppy-stucco-question-100_3697-small-.jpg.JPG
ID:	9014   sloppy-stucco-question-100_3696-small-.jpg.JPG
Old 2/8/07, 5:23 PM
staylor5's Avatar
staylor5 staylor5 is offline
Default Re: Sloppy Stucco question
Your correct. There should be no exposed wood. There should also be a waterproof barrier.
Old 2/8/07, 6:44 PM
Carl A. Brown's Avatar
There should be 2 layers of moisture barrier according to ASTMc1063.
The exposed osb on the bottom is not uncommon the carpenters and the form/concrete guy need to get their acts together. Thats not a stucco problem. What ever happens do not seal the bottom edge it will/can trap moisture in the wall system.
How were the windows installed? Backer rod and sealant joints? Flashings? Was ther kickout diverters?
More on kickouts! http://www.badstucco.com/phpbb/viewtopic.php?t=350
For the record they need to be on all houses no matter what the cladding!
Old 2/8/07, 7:35 PM
gbrasseur's Avatar
I am still not sure what to think of the opening in pics 1&2?
Old 2/8/07, 7:40 PM
They should be cleaned up and sealed with backer rod and sealant.
They are vertical?
Old 2/8/07, 7:44 PM
gbrasseur's Avatar
They are vertical?
Yes they are vertical. Notice the one picture with the window well?(pics1&2) Pictures 4&5 are from the bottom near the same spot. Thanks by the way!
Need to ID type of stucco cdewitt Exterior Inspections 20 12/4/06 11:39 PM
Stucco course badair Inspection Education & Training 2 11/21/06 6:51 PM
Stucco Question Tab M. Wilcox Exterior Inspections 9 11/19/06 3:46 PM
Stucco and Building Wrap eyerise Exterior Inspections 5 6/29/06 9:35 AM
