Old 2/25/07, 11:45 AM
kmcmahon kmcmahon is offline
Please Note: kmcmahon is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Smartside siding material
New stuff I ran into a couple of days ago.
·Smartside siding (engineered wood)
http://www.lpcorp.com/lpsidingproduc...smartside.aspx
How Are LP® SmartSide® Products Made?
So what makes LP SmartSide products so innovative? They're made by LP®, a recognized leader in engineered wood technology. Our team of experts developed a process to make our exterior lap siding, trim and fascia, soffit and panel siding look beautiful and perform exceptionally well in tough environments. When you choose LP SmartSide's engineered siding products, you're getting durability that lasts for many years.
All of our products are manufactured using the SmartGuard® process. This zinc borate-based treatment helps LP SmartSide products resist fungal decay and termites. We also utilize an advanced resin that adds exceptional strength and increased weather resistance.
Old 2/25/07, 11:49 AM
Default Re: Smartside siding material
server is down right now it appears for the LP site.
Old 2/25/07, 12:58 PM
Harold E. Miller's Avatar
Harold E. Miller Harold E. Miller is offline
Smart Side LP products have been around since 1997...they came out as a replacement to the LP Inner Seal products that were involved in class action lawsuits, and can still be found rotting, buckling, swelling, etc on many homes built or re-sided mostly in the 90's.
I have seen alot of failed Inner Seal, but have yet to see any failed Smart Side (panel or lap) products. And I have inspected hundreds of homes with LP Smart Lap and Panel. Like anything it has too be installed right, and sealed and painted properly.
Old 2/25/07, 1:01 PM
This is the first home I have seen it used...it was brand new construction and the siding was buckling in a few locations.
The owner was under the impression that it was factory painted.
Old 2/25/07, 4:45 PM
Bruce A. King's Avatar
good info
Its nice to see you back on here Kevin!
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 2/25/07, 6:53 PM
I was thinking the same thing.
I hope you are well Kevin.
Larry Kage, CMI
231 929 3525
Old 2/25/07, 10:36 PM
Thanks guys....I had to think hard about staying in this business...after 3 years I'm still not where I wanted to be at, however it is improving slowly...by the time I'm 50, maybe this will make me enough money to breathe easier.
Old 2/26/07, 7:35 PM
Kevin;
Nice to see you come back here. Haven't read some of your good posts in a while. Where have you been, if I can ask.
Hope you are well and back to the NACHI Family.
Marcel
Old 2/26/07, 8:12 PM
Peter C. Russell's Avatar
Smart siding, if it's the same product I'm thinking of is nothing more that a thin 4x8 sheet of OSB with a laminate front and then primed. Junk!!!!!!!
Remember Masonite!
Old 2/26/07, 10:59 PM
Remember Masonite!
There are lots of products that fit that desription made by a multitude of manufacturers' and it is not my first choice. Any wood based product becomes junk when it is not installed right, not caulked and painted right, and most of the problems is homeowners that just don't take care of it.
I personally like Hardi-Plank, which is mostly concrete based. I have it on my house and it does not rot.
Old 2/26/07, 11:08 PM
poliner's Avatar
poliner poliner is offline
Please Note: poliner is a non-member guest and is in no way affiliated with InterNACHI or its members.
Remember Masonite!
I have got to agree, these products are probably great when tested after 100% recommended installation practices. Problem is very few contractors have time or inclination to follow correct protocol.
Upshot:- homeowner has a "fragile" product that needs an inordinate amount of TLC.
OSB has too many sponge like qualities in any incarnation.
Old 2/27/07, 12:05 AM
Originally Posted by mcyr
Kevin;
Marcel
I've been here where I've always been....just spent some time contemplating a career change...but plan B wasn't a viable option, so I decided to stick it out and get more devoted to my home inspection career. So I'm back here learning as much as I can from everyone here and providing any advice I can give.
I also agree that most composition siding is junk...my client was real impressed with this stuff, but I hadn't heard of it so I just kept my mouth shut until I learned a little more about it.
Here's a couple photo's of the siding buckling...
smartside-siding-material-farris-002.jpg   smartside-siding-material-farris-003.jpg
Old 2/27/07, 5:17 PM
I also like hardi plank, great product but with limitations too.
Old 3/1/07, 6:39 PM
Kevin;
Was that Hardi Plank siding that was intalled to tight, butt joints not primed, not 1/4" from window jambs and not back primed?
Marcel
Old 3/1/07, 6:53 PM
ldapkus ldapkus is offline
Here's the website. I see it a lot on new construction.
http://www.jameshardie.com/homeowner...me/default.php
Asbestos jlybolt Exterior Inspections 41 7/17/07 1:13 AM
Asbestos Siding jwisecup Exterior Inspections 18 11/9/06 6:11 PM
Siding recall? slarosa Exterior Inspections 1 10/3/06 1:11 PM
Soft Siding jcooper2 Exterior Inspections 5 8/10/06 7:02 AM
