Old 1/4/10, 1:26 PM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Default Snow filled window well
This is no longer an emergency egress or escape window.
Mid America Property Inspections, Inc.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
KS-Radon Cert.# KS-MS-0035
KS-Termite Cert. # 18933
M0-Termite Cert. # N 5033
Find an InterNACHI certified Arizona Home Inspector (and anywhere else in North America)
Old 1/4/10, 1:29 PM
ldapkus ldapkus is offline
Default Re: Snow filled window well
I always recommend window well covers to keep out animals, small kids and debris.
Old 1/4/10, 3:51 PM
Douglas Cossar's Avatar
Douglas Cossar Douglas Cossar is offline
Me too
Doug Cossar CMI, NHI
Accurate Home Inspection
Services Inc.
Whitby Ontario
www.accuratehomeinspections.ca
05021384
Old 1/4/10, 5:05 PM
James F. McKee's Avatar
or maybe even to keep someone from falling into that big hole....
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 1/4/10, 7:35 PM
Marcel Gratton's Avatar
That window appear's fixed...
On The Level Inspection
Gatineau, Québec
Old 1/5/10, 5:14 AM
Peter C. Russell's Avatar
It does doesn't it, maybe it's a casement?
Old 1/5/10, 8:35 AM
It's a casement window.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
Old 1/5/10, 5:15 PM
David P. OKeefe's Avatar
David P. OKeefe David P. OKeefe is offline
Window well covers are good, just have to remember to clear the snow off the top. Easy to open the window but try and lift a cover that's covered in snow and ice. Especially for a child.
David
InterNACHI #08051301
NYS Lic. #16000038229
NYS DEC Cert # T4865884
518-505-8305
HouseAbout Home Inspections
HouseAbout on Facebook
NY Capital Region Chapter InterNACHI
Old 1/5/10, 5:50 PM
Buck, I see that all the time here also. I am surprised that counties do not require some sort of railings around these "pits"; they should. Most have drains at the bases, but should all have ladders. I always suggest domed covers on the small ones only. I always ask the buyer if they have kids. I have seen a couple with loose chain-link fencing over the egress that can be popped up over the holding pegs holding it in place.
And I always see trim over windows that needs caulking/flashings. I see the groove gaps.
Old 1/5/10, 9:10 PM
cmcdonald cmcdonald is offline
Please Note: cmcdonald is a non-member guest and is in no way affiliated with InterNACHI or its members.
My first thought is to bring this to the clients attention, as they may not be aware of the need to keep the means of escape clear and accessible.
Also, I could be mistaken, however in the photo it looks like the window could interfere with access to the ladder, which would create another escape issue... Was any information taken to determine if the window will open where it will not interfere with access to the ladder?
Just my two cents.
Chris McDonald
Old 1/6/10, 9:00 AM
Anyone who has even been to why-not-Minot is not alarmed by the what-if snow scenario.
While stationed in South Dakota many moons ago, I decided to visit my brother during the spring........little did I realize that they can still get snow storms from time to time. When I arrived (freezing my butt off) I saw snow drifts that were 10 feet high, often covering whole sides of apartments and homes.
With that said, I can assure you that those windows and doors were not usable for egress either.
Doors and window wells should have a drain......but to say they need a cover is a little ridiculous in light of the fact that a 10 inch snow over a larger cover can not only bury them you have also created a condition where no natural light exist which can be problematic if electrical goes out or their is an electrical fire.
In regards to the depth of window wells, they should be no deeper than that which is required for the max height to the bottom of a window.
Need help flashing top of replacement window on brick wall !!! Bill Featherstone Exterior Inspections 5 6/26/10 10:25 PM
Leak in bay window with copper roof hmiles Exterior Inspections 19 11/22/08 8:37 AM
The Weight of Snow mcyr Miscellaneous Discussion for Inspectors 2 12/23/07 8:53 PM
CPA of Health Canada reminding us of corded window coverings. gromicko Canadian Inspectors 7 4/23/07 7:31 AM
