Home was built in 2006.
Vinyl siding. Rust/dirt colored stains located around entire home below siding on exterior block. What are the stains from? How would you report, what would you recommend? |
Need more pictures and info.
David could You tell if there was a weather barrier /house wrap under the siding ????
It turned out the realtors husband who is an inspector and in one of my associations looked at it and he had no clue either. I have no more pictures. |
well i can't be of much help other than to say I think osb with no house wrap under vinyl siding...just my opinion....jim
Stains from rotting OSB. ??
Are the stains random or under doors and windows and other penetrations? "I create controversy whether they like it or not" |
Not below any windows or doors. |
Anyone in the area do IR scans?
Did you get a chance to read my return email to your mass mailout over the week-end? |
Yes Brian I read it along with a few others I got.
Just a thought....
Could this just be staining from dirt and whatnot being washed off the siding from the sprinkler system? I've seen similar staining when sprinkler heads were spraying water on the house. Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
No sprinkler system, but I was thinking along the same track about possable dirt from original build and grade. But then when I see the pattern of the stains it looks like it is from the siding. I hate not being able to figure it out or pinpoint the cause. Ever watch the show Finder Fixers on DIY? Great show!! |
It all depends on when the stains showed up. If the stains appeared during construction I would say a good rain came through before wrap could be applied to the house. If that was the case you might have concern for water damage to the OSB. If the stains didn't appear until after the house was sided unless I could visually prove weather barrier material doens't exist I would have to go with Mark.
Bill Boerner STL Home Inspection Services LLCServing St. Louis/Surrounding (314) 805-2137 office@stlhomeinspector.com http://www.stlhomeinspector.com Residential, Commercial, Radon, Termite, Lateral Sewer Scopes |
| Do you unzip vinyl siding? | apfaff | Exterior Inspections | 13 | 7/23/08 8:49 AM |
| Composite Concrete siding Issues I need Help | rkie | Exterior Inspections | 13 | 5/1/08 7:27 PM |
| ALCOA vinyl siding one side warping, why? | Lynn Kelly | General Inspection Discussion | 4 | 5/23/07 4:32 PM |
| Vinyl siding window trim | jclark1 | Exterior Inspections | 14 | 6/6/06 9:46 PM |
