Go Back   InterNACHI Message Board > Specific Inspection Topics > Exterior
Exterior Contains discussions about the exterior portion of a home inspection. This includes roofs, gutters, downspouts, decks, patios, windows, et cetera.
Old 11/4/09, 10:17 AM
David C. Macy's Avatar
Default Stains at vents/roof
Stains around roof top vents.
The roof was one layer standard 3 tab shingle about 10 years old. Gable/moderate slope.
House had soffit/gable/roof top venting. Insulation was loose fill about 6-9 inches. No moisture stains in attic, ventilation seemed to be adequate.
So what is causing the stains around the vents?
How would you report the scenario?
Would an active vent like a power vent be an solution? Or maybe adding more soffit vents. (There were no baffles installed but the insulation was not blocking the vents.
Thanks for the time.
Find an InterNACHI certified Alaska Home Inspector (and anywhere else in North America)
Old 11/6/09, 7:00 PM
Default Re: Stains at vents/roof
Did the rooftops of neighboring homes have the same problem?
EXPERT WITNESS
Director of Green Building
Director for International Development
(303) 717-8940
(303) 258-8289
Old 11/6/09, 7:04 PM
I did not look at any other roofs.
Old 11/6/09, 8:54 PM
I don't know. It looks like some kind of airborne particulates coming out of the attic plated out on the shingles. The source of the particulates?
  • What's the fuel for the heating system?
  • Did any exhaust flues terminate in the attic, including bathroom vents?
  • Was there a whole-house fan?
  • Was there any discoloration of wall or ceiling surfaces in the living space or of framing or sheathing in the attic?
  • If moist air was evacuated through the roof vents, it could be algae, although if those roof vents were galvanized and that was algae, there would be clear streaks on the downhill side from runoff, since algae doesn't like zinc.
EXPERT WITNESS
(303) 717-8940
(303) 258-8289
Old 11/6/09, 9:06 PM
Mark A. Vaage Mark A. Vaage is offline
Do they have a wood fireplace?
Old 11/6/09, 9:29 PM
William Warner's Avatar
William Warner William Warner is offline
Looks like over spray pattern to me (like spray paint or some chemical put on the vents). Certainly is interesting what ever it is.
Old 11/6/09, 10:37 PM
Good question Kenton. Looks like an unexplained anomoly to me. If there was no dicernable damage I might not call it out, or you might recommend to monitor it.
Either way great pic and interesting
"Never ever threaten anyone in Camoflage"
Tim Wilson
"Not everyone follows the same path"
Governor Sanford, musings on the Appalachian Trail
Old 11/6/09, 10:41 PM
Natural Gas
Possably one bath vent. Termination not visible but may of discharged at a soffit. (Covered with insulation)
No
No
No stains at plumbing stack.
Old 11/6/09, 10:42 PM
Yes the home did have a wood burning fireplace. It was at a lower level slab.
Old 11/6/09, 10:47 PM
Bob Elliott's Avatar
Got any attic pics?
This was a Condo building roof ,so I never got to the attic or roof due to no access.
22 footer not enough, but I did notice the stains.
Old 11/6/09, 10:52 PM
Originally Posted by belliott View Post
Got any attic pics?
No, there were no visible issues. In the upper attic. Insulation, roof structure and even the ventilation seemed fine.
The lower attic had some indications of past leaking from an upper rrof downspout discharging onto the lower roof surface. (They recently extended)
Old 11/6/09, 10:56 PM
Your picture looks like a one time event the way it is all so even .
Old 11/6/09, 11:12 PM
They were not shadows as it was cloudy. Maybe I was in the twilight zone!!
Old 11/7/09, 8:28 PM
Is there a possible leak in the attic from the fire place?
Old 11/7/09, 8:51 PM
James F. McKee's Avatar
sure looks like smoke damage David but You are not saying anything that would indicate that as a possibility....maybe it was martians...
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
ceiling stains wsiegel Interior 8 11/6/09 9:16 PM
Interior stains rbusch Structural 3 10/6/09 4:45 PM
Stains on masonry blocks. dmacy Structural 3 5/9/09 5:25 PM
Help with stains on interior wall/ceiling rborders Interior 2 12/22/07 12:58 AM
Stains on brick beside chimney jfunderburk Structural 23 11/29/07 10:02 AM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
