Old 8/8/09, 5:17 PM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Default Staples
Would anyone say this a a defect? Staples through the paper. This a wood roof.
Thanks!
Mid America Property Inspections, Inc.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
KS-Radon Cert.# KS-MS-0035
KS-Termite Cert. # 18933
M0-Termite Cert. # N 5033
Find an InterNACHI certified New Hampshire Home Inspector (and anywhere else in North America)
Old 8/8/09, 5:52 PM
James F. McKee's Avatar
Default Re: Staples
never installed a shake roof Buck but those staples sure can't be holding anything as i see it ..
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 8/9/09, 8:14 PM
wsiegel wsiegel is offline
Default Re: Staples
Not only are they wrong, but they can also leak
Old 8/9/09, 11:21 PM
Default Re: Staples
If you are going to write it up.......then its not based upon the felt paper (which is not going to do a thing to stop a leak) but rather the nailing / fastening requirements.
Your typical wood shingle / shake will have no less than 4 fasteners in each shingle;
because of the spacing of the 2x4's in relation to the nailing pattern of the shingle, you will have this from time to time. I see no picture of the shakes / shingles in question that would give me additional information which could be vital.
regards
Jeff
Old 8/10/09, 6:51 AM
David P. Valley's Avatar
Default Re: Staples
Thanks!
Buck,
Are they wood shakes or shingles?
Old 8/10/09, 6:12 PM
Mitch A. Harris Mitch A. Harris is offline
Default Re: Staples
Even with shakes I like solid sheathing, but when installed over spaced planks you are bound to have a few errant staples, these staples could still be covered by the 18 inch laced felt, if there are no signs of moisture penetration, I don't think I would call out a few staples that did not hit their mark.
[]Mitch Harris
Harris Home Inspections
mitch@harrishomeinspections.com
Your Central Kansas Pro-Sight affiliate
www.prosightinspections.com/HHI
Old 8/10/09, 9:07 PM
Marcel Gratton's Avatar
Default Re: Staples
2 nails each shingles should be sufficient for cedar shingles.
You may miss a board occasionally but another nail or two are usually a hit. Those blank shots should not result in any problem leaks as wood expand when wet and should seal those small openings in my opinion.
Anyone saw outside light when in an attic covered with cedar shingles on spaced planks and when rain starts, witnessed that light dim...
On The Level Inspection
Gatineau, Québec
Exposed Staples on Cedar Shake Roof pdickerson Exterior Inspections 6 7/19/08 11:54 PM
staples in places nails go? cbell1 Exterior Inspections 7 2/21/08 3:53 PM
Sign up for this exclusive NACHI deal from Staples. gromicko Special Discounts for InterNACHI Inspectors 3 5/6/07 9:31 AM
NACHI partners with Staples. Sign up now for free shipping and corporate discounts. gromicko Miscellaneous Discussion for Inspectors 7 5/2/07 10:22 AM
