Is this appropriate verbiage for staples on architectural shingles?
"Staples were used to attach the shingles to the decking material. Staples are not a recommended fastener by most asphalt shingle manufacturers and industry organizations. Further, the exposed staples on the ridge cap are not sealed which could lead to leaks. I recommend a licensed roofing contractor service the roof as needed." Kenny Rigler Home Inspections Hays, KS 67601 785-656-0272 |
| Need a home inspection in North Dakota? Check out InterNACHI's listing of North Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I would say that sums it up. The staples could also void any type of warranty or insurance claim if they are not the recommended fasteners.
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
Staples can be used on many different shingle applications. However, they are usually installed 4 per shingle and in line with the upper and lower edges. The one under the tab in your picture is installed at an angle which is wrong. Also the ridge cap should not be attached in that manner as it will likely lead to leaks developing. Looks like a boched job to me.
Scott Gilligan 215-888-4943 Infraspection Institute Level III Certified Thermographer Philadelphia Mold Inspections Philadelphia Home Inspections Philadelphia Commercial Inspections Philadelphia Licensed Home Inspector Pennsylvania - New Jersey - Delaware Infrared Thermal Imaging Inspections President The Greater Philadelphia Chapter of InterNACHI http://pa.nachi.org/greaterphiladelphia Vice President & Webmaster National Association of Commercial Building Inspectors and Thermographers |
obviously the cap shingles were fastened by someone without a clue...the fact they used staples has little bearing on the fact that they had no idea how to fasten the shingles....jmo....jim
Staples equal problems down the road..... it is also a sign of a cheap arse roofer who often will take short cuts. I have never seen a roof where staples were used that there were some sort of problems.
Was it a MFG home? Most of them staple the shingles one, but definitely not the cap.
Any exposed nail or staple is wrong. High nails or staples are common and need to be repaired. I would change my wording and remove the word "service" and replace it with "repair". Also, dont know what your codes are, but staples have not been used in south Fl since 1994
No, it was a standard style ranch, built in 1982. Rigler Home Inspections Hays, KS 67601 785-656-0272 |
The city uses the IRC 2006. I called the city inspectors but didn't really get a definitive answer from them. The ones on the ridge caps have obvious problems and I'll note the weakness of using the staples throughout. Thanks. Kenny Rigler Home Inspections Hays, KS 67601 785-656-0272 |
Staples and nails have similar wind resisance if they're installed correctly, however staples are seldom installed correctly. The crowns must be installed parallel to the long axis of the shingle. It's obvious that the staples on this roof did not adhere to the manufacturer's recomendations. Manufacturers never condone exposed fasteners of any kind. Both cap shingle and field shingle installation is defective in this case. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
| Foam Insulation Requires roof Ventilation | dvalley | Thermal Imaging, Infrared Cameras & Energy Audits | 30 | 9/4/10 2:43 AM |
| Shooting to begin on comprehensive new roofing courses | kshepard | Inspection Education & Training | 4 | 11/7/09 2:59 PM |
| 3 tab shingles curling | ccbrands1 | Exterior Inspections | 8 | 1/29/07 5:25 PM |
