Old 1/16/06, 9:08 AM
jlybolt jlybolt is offline
Please Note: jlybolt is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Step flashing at vertical wall?
Just about all the homes I inspect have L shaped flashing in lenght of say 10 feet were the roof line meets a vertical wall. (new construction and old construction) All of my references call for step flashing in these situation. I just wanted others opinions. Should it always be step flashing? If so how do you write it up? Thanks
Old 1/16/06, 9:27 AM
Dale Duffy's Avatar
Default Re: Step flashing at vertical wall?
In Arizona they use one piece of continual L-Flashing or what we call Sidewall Flashing
In my opinion and the Building inspectors, one peice or 10 foot lengths is much better than numerous pieces of step flashing, especially in conjunction with stucco. Some contractors with a flashing Break will make the entire length on-site from roll stock.
Old 1/16/06, 10:59 AM
Carl Brown Carl Brown is offline
Please Note: Carl Brown is a non-member guest and is in no way affiliated with InterNACHI or its members.
Are they useing kickouts at the bottom? No matter what kind of cladding?
http://www.dryflekt.com
Old 1/16/06, 3:06 PM
lewens's Avatar
lewens lewens is offline
Send a message via AIM to lewens
Please Note: lewens is a non-member guest and is in no way affiliated with InterNACHI or its members.
The less the joints in any flashing the less the chance of water backing up under it. I go with the long runs. The only time I want to see step flashing is when it is properly set into brick morter.
Larry
Old 1/16/06, 3:08 PM
no, very seldom do you see kick out flashings. A big concern of mine is when the roof meets at a column usually for an upper portion of the roof. The problem is the brick sticks out a little further than the veritical wall. It looks like a place for disaster. See picture.
Old 1/16/06, 3:31 PM
Dale Duffy's Avatar
Kick-Out?..........
step-flashing-vertical-wall-kickout2.jpg   step-flashing-vertical-wall-kickout.jpg
Old 1/16/06, 4:18 PM
Woops, here is the picture. See were roof meets brick. This job I was able to actually look between the vertical wall and brick and see exposed 2x4 studs.
There was flashing though.
step-flashing-vertical-wall-capt002.jpe
Old 1/16/06, 4:28 PM
Dale Duffy's Avatar
Pathetic, but very typical for new construction.........
Old 1/16/06, 4:49 PM
mgifford mgifford is offline
The bottom of that vertical wood trim on the high side of the bricks will certainly rot in a few years. Dirt and debris will pile up against it and keep it damp after any perception.
Old 1/16/06, 5:13 PM
And then the roofers put their flashing on over the housewrap!!!!
http://www.badstucco.com/tybad/tybad.htm
Then the windows!
http://www.badstucco.com/windows/WINDOWS.htm
And the list just keeps on growing!
Where are their heads?
Old 1/16/06, 5:28 PM
Dale Duffy's Avatar
Carl,
Where are you getting all those wild pictures with the wood trim installed? Lawsuiteville?
Their applying stucco? or Vinyl-Aluminum Siding?
Old 1/16/06, 5:39 PM
Why do you say that dale?
Stucco for the most part and some hardy!
I can be reached toll free 1-888-830-2687 or email cabinkc1961@yahoo.com
That smart trim is not to touch masonry!
Its not stucco doesn't have enough problems the houses are set up to fail long before the succo contractor gets there! I have 27 years invested in the trade and last june I quit!
I am gonna find me another job!
Old 1/16/06, 5:46 PM
Originally Posted by dduffy
Carl,
Some of the pictures from the street some from the yard some from other guys that are tired 2!
Dale I am really suprised they haven't tried to shut my website down!
Old 1/16/06, 5:55 PM
Dale Duffy's Avatar
Not Me.....
I enjoy telling people, and writing for a fee how screwed-up their buildings are.
I have never seen a building with EIFS in which I could not find something wrong with the stucco or flashing.....NEVER....
Old 1/16/06, 6:08 PM
When the carpenters start installing the windows and the first layer of moisture barrier and the FLASHING!
And the roofers put their flashing behind the housewrap so there is two layers of protection when it is for stucco just like ASTM calls for,then some of the leaks will go away. As long as tyvek says to tape the flashing back to the wrap and tape all the horizontal joints. Trapping the moisture in when it gets in things wil just keep getting worse for the homeowner! IMO
I saw a post the other day about sayings heard on jobs!
The 1 I have heard the most!
(F___ it!! It aint my house!)
Sorry for the RANT!
VIDEO--Bowed Basement Wall, Cracks etc john bubber Structural Inspections 75 7/21/08 5:25 PM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 8:10 AM
Newbie here with a slab "standards" question Robert Young, #3 Structural Inspections 17 4/10/07 10:48 AM
exposed step flashing Rafael Exterior Inspections 9 5/8/06 12:25 AM
Wall flashing Matt M Exterior Inspections 3 3/20/06 7:08 PM
