Once again, builder's do not even attempt to follow "Best Practice" when placing stone veneer. Mortar placed tight to window and door trim with no backer rod or sealant. Stone set below grade, no weep screeds, mortar set on flashing tight to the roof. Concrete porch slab poured to the stone, etc.
| Need a home inspection in Delaware? Check out InterNACHI's listing of Delaware certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Real or synthetic??
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
David,
I agree, where are the local county imspectors? This is a one year old home, unfortunately there is no easy fix. I continually find some of these same installation errors at new homes. One well known national builder's on site manager admitted that the client will continue to have cracked mortar at the window amd door trim. Amazing! |
Here's good report language developed and "recommended" by the State of NC for home inspectors.
http://www.ncdoi.com/OSFM/Engineerin...neerSiding.pdf “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Thanks Joe
While fake stone like all other masonry should be done right, I had a long discussion a couple of times with an owens corning rep about their product. As of right now they do not make it manditory to install a screen at the bottom but it is suggested.
The biggest issue they were having was the builders not wetting the stones before install. The dry stones were causing the mortar to dry set and then fail later. Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
Around here if the installation instructions aren't in Spanish or Polish, it won't be done right.
BPI Certified Professional Building Analyst BPI Certified Envelope Professional Infraspection Institute Certified Level II Thermographer # 8510 www.dapkusinspections.com www.chicagoinfraredthermalimaging.com www.mychicagohomeinspector.com www.commercialbuildinginspectionchicago.com Professional Infrared Network Chicago Energy Audit Aerial Infrared Inspection Certified Infrared Thermal Imaging |
| Cracks in stone veneer | jgromkoski | Exterior Inspections | 14 | 11/8/10 9:49 AM |
| stone veneer and weep holes | jclarke | Exterior Inspections | 21 | 9/30/10 9:50 PM |
| manufactured stone verbiage | bking | Exterior Inspections | 12 | 9/21/10 6:17 AM |
| Veneer stone install question | vdisciullo | Exterior Inspections | 1 | 8/5/08 4:48 PM |
| Stone Veneer | jevans | Exterior Inspections | 3 | 10/19/06 8:21 PM |
