Found this at a porch install (new construction)
Two story porch system in the city. What would you guys say about that plywood between the stringer and the beam. Does it actually do anything to help? Is enough of that stringer making contact with the beam if plywood piece is not there?
| Find an InterNACHI certified Minnesota Home Inspector (and anywhere else in North America) |
In the report I mentioned that the Stringer appears to be cut short and plywood was used as a makeshift remedy.
Recommend professional carpenter inspect for safety. Anyone dis agree? |
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Sending report. Yeah working tonight because we had the party yesterday. |
Thats just not right.
Well my Brother had duty on Christmas so.......or do you mean the stringer??? |
This is a much better method:
And there is more Simpson hardware in the link at the bottom. of the article. http://www.decks.com/article72.aspx Stair Stringer Attachment How you attach the stair stringers to the top of the deck and to any landings will be critical. You should reinforce the rim behind the stairs to provide a solid base for attachment. Use positive connections to install stair stringers using joist hangers or angled brackets to the front face to provide adequate support. If your first tread steps down from the deck you must extend the rim joist to create a solid surface below the deck rim to attach to. You should attach a 2x6 or 2x8 under the rim flush to the bottom of the stringer using strap ties or bolted cleats for added strength. You may also want to use metal strap ties that can bend along the bottom of the stringer and over the top of the rim joist for added support. Attaching to the top of a landing offers a similar situation in which you should always maintain a solid face connection. For attaching stair stringers to the deck, the LSU26Z field slopeable joist hanger by Simpson Strong-Tie is a good choice. The hanger is sloped and skewed during installation to fit most stair projects. The LSU26Z has a ZMAX® coating for additional corrosion resistance and can be sloped up or down and skewed left or right up to 45°. Stair treads also must be properly connected to the stringers in order to support the weight of your deck. The TA9Z and TA10Z staircase angles by Simpson Strong-Tie provide the needed stair tread-to-stringer support and eliminate costly conventional notching. The angle installs at each end of the stair tread with ¼-inch x 1 ½-inch Simpson Strong-Tie Strong-Drive® screws (SDS) and has a ZMAX® coating for additional corrosion resistance. For more information about deck connectors and fasteners, visit http://www.strongtie.com/deckcenter InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
That is a good graphic Larry, and that is the way it gets done.
I tried to find a picture of mine this morning and could not find it. I do mine all out of wood with joist hangers (adjustable pitch) along with double rim joist. If I find it, I will post it for all. The picture that Bob posted will not go anywhere, but is not a proper way aesthetically to do it. First the plywood should be PT. Does not look right, and to answer Bob's question, no, the stringer does not have enough plumb cut to attach to the rim joist or joist to support it without the hangers or drop down header to allow for proper attachment with the adjustable rafter hangers. A stair stringer is similar to a rafter and laid out in the same fashion. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Thanks guys and in particular Larry on that one.
I just got off the phone with my client as I always reinforce my punch list verbally after the send. I will send the link. |
Here you go Bob, I found it.
This reinforces the link that Larry got. Can't see the back side but they get spliced with lumber on the drop down. ![]() ![]() And this one is just to prove I was there. ![]() LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Haha
Hey you are not such a bad looking guy. Change that ugly avatar. By the way do you recall amount of wood min required between tread / riser cutout bottom of riser board. In other words checking for overcut when stringer is custom cut. |
Looks like a 3-1/2 " min |
http://stairs4u.com/stairdonts/stair_don.htm
I have repaired the damage caused by poor construction and improper repairs from someone just trying to get by for a little longer until they have the money to fix it right. When it becomes a safety issue like the one below someone could get hurt and that's not good for anyone. Poor design and inexperienced building repairs that don't meet building requirements create safety hazards. If you see something like this where you live there is a good chance it can be repaired or rebuilt to avoid a accident.
Quick and Sturdy Stair Attachment
These are good instructions for installing deck stairs, stringers, using steel straps to make a strong support. Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
| comp roof install | tvargas | Exterior Inspections | 7 | 7/1/09 11:55 AM |
| How to install a water filtration system? | dmacy | Plumbing Inspections | 22 | 6/30/08 8:16 AM |
