Old 9/15/11, 12:37 AM
Andrew Cox Andrew Cox is offline
Default Stucco 2nd floor
On a 2 story house, concrete block 1st floor, wood frame 2nd floor, how wide should the drip edge be between floors? I was asked to look at a house with moisture problems - exterior walls all have moisture 15-20% in the drywall. I found the drip edge to be irregular - from 1/4" in some areas to almost 1" in others - not the best but would this in itself lead to increased moisture in walls?
Andy Cox
http://www.CoxInspections.com
Kissimmee, FL
You’re Your Own Job Security.
Need a home inspection in Ohio? Check out InterNACHI's listing of Ohio certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 9/15/11, 9:40 AM
Carl A. Brown's Avatar
Default Re: Stucco 2nd floor
Lack of moisture barrier causes moisture problems with block walls.
Got any pictures?
Old 9/15/11, 2:04 PM
Michael J. Meeker's Avatar
Michael J. Meeker Michael J. Meeker is offline
Pictures Please.
Florida Licensed General Contractor
Florida Licensed Home Inspector #299
Wind Mitigation Specialist
Call 954-922-0584 or E-Mail Me For The Best Wind Mitigation Inspection in Florida at a Great Price
Old 9/15/11, 9:32 PM
ROBERT V. YOUNG's Avatar
ROBERT V. YOUNG ROBERT V. YOUNG is offline
Remember that humid exterior conditions will increase the drywall's RH.
What are you using to measure the RH?
Does the tool have to be calculated for drywall?
Exterior walls all have excessive moisture reading as compared to what.
What is the relative humidity in the atmosphere?
When did it rain last.
What exposure did you measure East , West, North, South?
What time of day. Morning night.
montrealbuildinginspectionservice.com
montreal-home-inspection-services.com
home-inspections-montreal.com
homeinspectionsservicesmontreal.com
ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC.
Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI)
OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816
Old 9/19/11, 9:03 PM
Pete Campbell's Avatar
Pete Campbell Pete Campbell is offline
"Stucco inspections are easy. They are all wrong."-- Mark Cramer, ITA Legend
A 'drip edge' is the incorrect product for this app.
Correct product in Fort Pierce, FL is a weep screed.
The RH and other factors have little to do with this situation. The installation is all wrong and is causing water to be trapped in the wall behind the stucco. Left for 3+ yrs, this will result in structural damage to the wood framing that sits on top of the block.
KB Homes is famous for this horrible design flaw and has repeated its installation extensively in Sebastian, Vero Beach, Port St. Lucie and Stuart, FL. This problem is also very prevalent in the Orlando area where space is tight and going vertical packs more SF onto a small lot. Time is catching up to this type of house which got popular around here in the mid 2000's.
Good thing those new homes came with a 10 year structural warranty, but good luck trying to collect on tearing off all the deficient stucco and damaged framing and drywall. The A-Hs usually try to patch over on the outside, making it worse. Companies like KB should not be constructing houses that they don't understand how to design properly.
And worse, the AHJs don't even understand the Florida Building Code and ASTM Standards, so they let it pass. Incompetent idiots.
Pete Campbell
pete4545@comcast.net
http://www.PortStLucieInspections.com
http://www.ChooseGI.com
http://ifwemissitwewillfixit.com
Inspecting Fort Pierce, St. Lucie Village, Lakewood Park, Vero Beach, Indian River Shores, Sebastian, Fellsmere, Fort Drum, Okeechobee, Jensen Beach, Stuart, Palm City, Hobe Sound and Indiantown, Florida.
EIFS/Stucco mmerino Exterior Inspections 16 8/6/09 7:41 AM
Commercial Electrical Inspections jtedesco1 Commercial Inspections 29 1/12/08 5:03 AM
Max load allowed on 2x2 ledger bking Structural Inspections 4 12/23/07 2:05 PM
Where do I put the Aquarium? mcyr Structural Inspections 3 11/6/07 3:05 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 7:53 PM
