I am more familiar with the 3 coat application so when looking at a home with the 1 coat app. and I see a number of cracks (more then there should be) is this fixable with a good paint job or could this be a problem down the road. You can see where repairs have been made. Thanks for your help
David Garton Eagle Eye Inspection Services david@yubacityhomeinspection.com http://yubacityhomeinspection.com Licensed Building Contractor Serving Yuba City, CA. and the surrounding areas (530) 415-1269 |
| Need a home inspection in Wyoming? Check out InterNACHI's listing of Wyoming certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Is it frame constuction? If so it may not be able to hold up to the movement. Carl would know the best.
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
What makes you think this is a "1 coat" system? Stucco can always be "fixed," even if you have to start over.
what the inspector & client may need to know & understand
http://www.mnlath-plaster.com/librar...sinStucco2.pdf http://www.wconline.com/Articles/Fea...00000000073752 ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 7/18/11 at 2:10 PM.. |
Yes it is
Hollow sound? Could it be EIFS? This is an important item to note in your report.
Look for some information and pics on EIFS and your inspection. Inspectors have methods they use to discern if EIFS or not.. such as looking around penetrations, removing outlet cover (out of SOP) and so on. Some types can easily be identified in the attic, tapping on (you mentioned that one Nachi has a course as well... look for the links! |
some of the one coat and conventional hard coat is being applied over foam board insulation in this market
may sound like EIFS but really isn't considered EIFS by industry standards this seems to be the work-around for munis that have outlawed the usage of EIFS same old issues just disguised and labeled differently by the industry and building dept. if you don't know the difference defer to a specialist Nick will prolly post the Stucco/EIFS course link soon ;~)) ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
Barry should know He was around when they invented Mortar...
[QUOTE=badair;804051]some of the one coat and conventional hard coat is being applied over foam board insulation in this market
may sound like EIFS but really isn't considered EIFS by industry standards this seems to be the work-around for munis that have outlawed the usage of EIFS same old issues just disguised and labeled differently by the industry and building dept. You got it Barry, that is exactly what it is, no doubt!! David Garton Eagle Eye Inspection Services david@yubacityhomeinspection.com http://yubacityhomeinspection.com Licensed Building Contractor Serving Yuba City, CA. and the surrounding areas (530) 415-1269 |
| There are over 12 types of stucco and EIFS | bgromicko | Exterior Inspections | 0 | 12/19/09 7:04 PM |
| EIFS/Stucco | mmerino | Exterior Inspections | 16 | 8/6/09 7:41 AM |
| Stucco Issues | jfunderburk | Exterior Inspections | 19 | 3/7/09 8:15 AM |
| Whats with this Stucco!? | dandersen | Exterior Inspections | 19 | 4/12/08 11:33 PM |
