Old 12/7/08, 2:41 PM
lfoster's Avatar
lfoster lfoster is offline
Default Stucco cracking,
Looked at home built in 2001, stucco exterior, two story.
Flashing wasn't evident above windows, and all window trim lower pieces had cracking / splits. No kick out flashings.
The trim above the french doors was the same, with a lot of damage to even the side pieces.
Pretty sad shape for the age.
ID:	25572   stucco-cracking-101_2879-small-.jpg.jpg
ID:	25573   stucco-cracking-101_2877-small-.jpg.jpg
Old 12/7/08, 2:54 PM
Carl A. Brown's Avatar
Default Re: Stucco cracking,
Linda,
Was the trim foam with just a little stucco thrown at it?
No backer rod and sealant joints between the stucco and the windows?
That can be seen anyway.
No control joints?
All of the horizontal surfaces should have a positive slope to drain water to the exterior.
Old 12/7/08, 5:16 PM
lfoster's Avatar
Originally Posted by cbrown1 View Post
Linda,
Was the trim foam with just a little stucco thrown at it? trim was wood
No backer rod and sealant joints between the stucco and the windows? none visible
No control joints? not a one. well, take that back - at the soffit and the foundation !
What are the spans for control joints?
Usually place one to each side of window or door?
Here's a couple more pics.
ID:	25575   stucco-cracking-101_2875-small-.jpg.jpg
Old 12/7/08, 5:29 PM
Corners of all windows and doors and at the plate line between the first and second story.
No areas to be bigger than 144 sq. ft.
Old 12/7/08, 5:32 PM
In the picture of the trim if they built the trim out of cement the cracking/void is where they piled the trim on in layers to build it to thickness.
Was it cement or foam?
Old 12/7/08, 7:29 PM
lfoster's Avatar
I believe it was cement. Nothing else around there is foam.
Old 12/7/08, 7:38 PM
lfoster's Avatar
There were no control joints, anywhere.
Looked like the water had been running in behind the window / door trim, and then down and out where ever it could.
Wish I had a thermo camera to 'see in the walls'. Course, it's been so long since it rained here,,, may not be any left in the walls !
Old 12/7/08, 8:46 PM
How far are you from Dallas?
Old 12/7/08, 8:54 PM
lfoster's Avatar
150 - 200 miles. I guess.
San Antonio is 80 miles.
Old 12/7/08, 8:56 PM
Barry Adair will travel for the right amount.
It might not have rained for a while but the damage could still be there.
Old 12/7/08, 9:10 PM
lfoster's Avatar
That's a great idea.
I think the buyer will walk on this one, tho. If the buyer is interested, I will contact Barry to check the pricing. House is located in Uvalde, TX, appx. 100 miles W of San Antonio.
At the end of insp, he was saying he wished he had the inspection done before making an offer.
There were several problems besides the exterior. The electric sub panel in laundry had bar between both bus bars, mixed neut and grounds, and it was bonded. Would take a few bucks for electrician to fix. He wasn't a happy camper.
Just noticed this evening the stucco class in Boulder, CO on Monday / Tuesday. Wish I had seen it sooner.
Thanks for the help,
Linda
Old 12/7/08, 10:29 PM
Barry Adair's Avatar
Barry Adair will travel for the right amount. "Inspecting Texas for the Right Price"
It might not have rained for a while but the damage will still be there.
CB,
Thanks for your continued support!
Linda,
My next available appointment is 12-22-08...not cheap but they'll get the facts
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 12/8/08, 12:38 AM
lfoster's Avatar
Thanks, Barry. I will let them know when I speak with them. Will contact you accordingly.
Please respond privately to possible cost for exam.
2,275 sq. ft.
2 story
All exterior walls are stucco
Thanks,
Linda
HomeInspectionsByFoster@yahoo.com
Stucco Flaws jbettencourt Exterior Inspections 8 7/22/08 3:43 PM
Stucco Finish on Superior Walls krichardson Exterior Inspections 8 4/30/08 8:18 AM
Whats with this Stucco!? dandersen Exterior Inspections 19 4/13/08 12:33 AM
Stucco course badair Inspection Education & Training 2 11/21/06 6:51 PM
Wisconsin stucco problem dnice Exterior Inspections 6 10/17/06 9:03 AM
