Hey Guys,
I need some help. I'm not a Stucco expert as there is not that many homes in my area that have Stucco siding. In addition, this newly constructed house I inspected yesterday was built with a Superior Wall foundation. The very first one I have come across in my area. So, my question is with the way the builder applied the Stucco on the exterior of the superior walls. Superior walls are pre-cast sections, and the builder left the corners and all joints for the pre-cast sections unfinished, then applied caulk at the joints. This just didn't look right to me, but the builder threw a fit stating that the Stucco was not allowed on the joints or corners due to expansion. While that made sense to me, my argument was that the exterior caulk used to seal the corners and joints will eventually deteriorate leading to moisture intrusion or at least water seeping behind the Stucco. Therefore, what do you think? Is this right? Thanks in advance for any advice Kevin Kevin A. Richardson Level III Infraspection Institute Certified Infrared ThermographerŪ, #7493 Infraspection Institute Thermography Instructor BPI Certified Building Performance Analyst RESNET Level II Home Energy Survey Professional Maryland Licensed Home Inspector, #29727 InterNACHI Certified Professional Inspector, #04091175 301-942-4610 www.richnspect.com www.infrared-diagnostics.com www.thehomegreenteam.com |
But yet they wrapped the stucco trim around the corner!
The caulk joints to have to be maintained as do the ones around the windows and doors! Is that Faux stone on the bottom? If so what did they do with those corners? "I create controversy whether they like it or not" |
And it might just be a thin cote of acrylic base cote and finish over the concrete! No lath and moisture barrier involved.
Kevin,
Answer your phone! ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
Richard W. Washington, owner RW Home Inspections, Inc. www.RWHOMEINSPECTIONS.com Texas Real Estate Commission (TREC) Professional Inspector License #7238 Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter InterNACHI member since 2004 Based in Katy, serving Houston and all surrounding communities |
Mr. died many moons ago
Superior wall how are inside/outside corners constructed/sealed without further application of conventional moisture/vapor barrier papers/wraps at the exterior? Then a thin at best application of synthetic stucco products unless further information has been omitted and our all time favorite a butt ugly fillet caulk sealant joint used to prevent moisture intrusion...this tells me we have a system that is designed/destined to fail...I'll stand on this until proven wrong Suggest application of floating EIFS trim caps at corners with doubled ribbon beads of low modulus sealant. This should allow for movement and maintain weather proofing. HTH ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good Last edited by badair; 4/30/08 at 12:02 AM.. |
Barry, Instead of posting this here you should contact the mfgr. and sell them the improvement on their system. Smart man! "I create controversy whether they like it or not" |
| Stucco Question | rkeith | Exterior Inspections | 3 | 4/28/08 9:04 PM |
| Whats with this Stucco!? | dandersen | Exterior Inspections | 19 | 4/12/08 11:33 PM |
| Need to ID type of stucco | cdewitt | Exterior Inspections | 20 | 12/4/06 10:39 PM |
| Stucco course | badair | Inspection Education & Training | 2 | 11/21/06 5:51 PM |
| Wisconsin stucco problem | dnice | Exterior Inspections | 6 | 10/17/06 8:03 AM |
