Once before I confused a weep screed with a control joint. Don't want to do that again. What about this one? Weep screed or control joint?
Pic 1: Pic 2: ![]() Proper flashing for a door (below)? Pic 3: ![]() Thanks. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com Last edited by jfunderburk; 3/7/11 at 8:46 AM.. |
| Need a home inspection in Minnesota? Check out InterNACHI's listing of Minnesota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
And the Window is not flashed right, a I'm sure you know. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
None of the photos I showed illustrate what I think a weep screed should look like.
I thought a weep screed would look like this: ![]() Or like this:
And a control joint should look like this (which is what I think is in Pic 2).
Hi Joe
A stucco contractor can strike control joints in the finish just using Lath without what you have pictured, basically like a concrete floor, but a wall. Use a Chalk-Line, strike control joints with tool, helps alleviate a lot of cracking. The weep flashing you have posted is weep. Can't see if what is installed without destructive testing. Doesn't look right from here. And by looking at the window without backer-rod-sealant joints, destined to fail. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
The "weep-screed" is generally reserved for the lowest termination point of the stucco system. While "weep-screed" is a flashing, it is perforated and serves a specific purpose.
Standard flashings are used around windows, doors, roof-transitions, etc., and are not usually perforated except for nail-holes. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
I don't see anything resembling a weep-screed in any of the pictures in your original post. They all appear to be standard flashings.
Doesn't matter what type of siding it is up here. They put the head flashings on wrong 99% of the time. Usually they just put the flashing on top of the house wrap and cover it with the siding. Of course they also install the windows incorrectly most of the time.
Luckily we have very very very few true hard coat stucco applications up here and only a few more EIFS. Thanks for that. Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
What I thought. Thanks Jeff.
Not what Joe has posted in the first pics., his looks like a mess regardless of what it is...or where it is. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Joe,
Some interesting photos. Following are my thoughts: Is photo #1 at the top of the foundation? This is an atypical location for the visible flashing. It appears to be a "water table" type of flashing between the Hard Coat Stucco (HCS) above and foundation below where the HCS may have come down on top of the foundation wall requiring the flashing that is visible. The bottom of the HCS should have a weep casing as shown in the lower photo of the 1:43 Post: there is discussion as to whether weep holes are absolutely necessary in a bottom termination casing, however, I prefer to see them. The upper photo in the 1:43 post is what is technically defined as a Weep Screed; it does not appear to be present in the photo. A weep screed as noted is typically used at the bottom of walls to lap the top of the foundation. Photo #2 appears to be the intersection of control joints as shown in 9:45 AM post. Photo#3. Is of a window jamb and head detail. As previously noted the sealant joint around the window is incorrect per NWCB specifications; however, some HCS manufacturers allow what there. I agree with comment that it will fail if constructed as picture shows. The head has a head flashing; we can not see if flashing properly integrated with flashing papers and weather resistive barrier above window during a home inspection. Ideally, there should be an end dam on the window head flashings and drainage provisions above the flashing to let incidental water out of the wall cladding. Most manufacturers call for sealing of the window head flashing to the window head below; this appears to be missing. Thus, Photo #1 need some additional information to determine if a problem or not. Photo #2 appears to be proper although not common on single family homes in Metro Denver. Photo #3 warrants further investigation by a stucco expert such as an EDI or AWCI certified stucco professional. Hope this helps. Ron |
| Need help with roof flashing question | kshepard | Exterior Inspections | 7 | 7/12/09 5:24 PM |
| Deck flashing question | scosta | Exterior Inspections | 7 | 10/15/07 11:21 PM |
| Stucco Question | Tab M. Wilcox | Exterior Inspections | 9 | 11/19/06 2:46 PM |
