Old 11/11/08, 3:51 PM
tmcsweeney tmcsweeney is offline
Default stucco inspection
although I have been doing inspections for several years now, I haven't had to inspect a house with a stuuco exterior. Could someone tell me how to determine stucco vs EIFS or synthetic stucco Thanks Tim
Old 11/11/08, 5:54 PM
Carl A. Brown's Avatar
Default Re: stucco inspection
Easiest way is to pull a light fixture or exterior plug cover.
Look under the bottom edge.
Tap on the wall EIFS sounds hollow stucco for the most part does not.
For starters.
Old 11/11/08, 5:56 PM
dbucknavich dbucknavich is offline
Please Note: dbucknavich is a non-member guest and is in no way affiliated with InterNACHI or its members.
Or start here
Want to know why your house is leaking?
Here
Old 11/11/08, 6:00 PM
Carl, here are some pictures from the house I talked with you about yesterday. Thanks again.
stucco-inspection-cimg0390.jpg   stucco-inspection-cimg0395.jpg   stucco-inspection-cimg0391.jpg
Old 11/11/08, 6:06 PM
From where I sit that looks like stucco with paint.
Post those in the other and we will see what peewee has to say.
Does it have weepscreed?
Old 11/11/08, 6:09 PM
No weep. The file is too large for the other. but I think I was attaching several pics. I will attach single pics.
Old 11/11/08, 6:11 PM
Metal casing bead?
Old 11/11/08, 6:21 PM
Metal casing bead?
No access. Didn't see anything. Don't know of you can tell by the pics, but the finish is below grade, and where I can see the wall terminate, it sits on stem wall, almost flush with it. Again, nothing but the finish is visible
Old 11/11/08, 6:23 PM
Here's a twist. The house has an original guest house, with one coat and weep. Felt different too. Much harder than main house with that solid feeling instead of hollow.
Old 11/11/08, 6:33 PM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
Carl is a big help on these issues.
Check out his web site , if you have not yet.
I think he is up for website of the month.
Old 11/11/08, 7:44 PM
Peewee Kline Peewee Kline is offline
Please Note: Peewee Kline is a non-member guest and is in no way affiliated with InterNACHI or its members.
I agree......Looks like a one coat brown and Texture job.Not much can be done to repair ths cracks.A very heavy coat of elastomeric paint can help besides tearing it off and starting over.
Old 11/11/08, 8:13 PM
Thank you peewee. What is the deal with the flex upon pushing the wall? I couldn't imagine the attachment is very strong.
Old 11/11/08, 8:49 PM
Look up under the bottom termination. If you see white foam, it's EIFS. If you don't, it's probably hardcoat stucco but not definitely. Watch for the InterNACHI course in this subject coming out on video in late December or early January.
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 11/11/08, 8:52 PM
Thanks Kenton. The pics I posted is the best look I had at the bottom. Not much at all actually.
Stucco Flaws jbettencourt Exterior Inspections 8 7/22/08 3:43 PM
Stucco Finish on Superior Walls krichardson Exterior Inspections 8 4/30/08 8:18 AM
Whats with this Stucco!? dandersen Exterior Inspections 19 4/13/08 12:33 AM
Stucco course badair Inspection Education & Training 2 11/21/06 6:51 PM
Wisconsin stucco problem dnice Exterior Inspections 6 10/17/06 9:03 AM
