Go Back   InterNACHI Message Board > Specific Inspection Topics > Exterior
Exterior Contains discussions about the exterior portion of a home inspection. This includes roofs, gutters, downspouts, decks, patios, windows, et cetera.
Old 12/5/07, 11:13 PM
Russell J. Hensel Russell J. Hensel is offline
Please Note: Russell J. Hensel is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Stucco over concrete block
The stucco on a concrete block house has cracks that show the area of the underlying concrete block, (Looks like stairs) It is aesthetically displeasing and it is in an upscale neighborhood. It is the only house in the neighborhood with this problem. I was wondering what the typical cause was. The house is located in SW Florida
Old 12/6/07, 12:16 AM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Stucco over concrete block
Need more info and a pic sure would help.
What is the stucco imbedded on?
Not directly on the CMU I would hope?
Old 12/6/07, 8:48 AM
Carl Brown's Avatar
Carl Brown Carl Brown is offline
Yes!
No moisture barrier and lath to hide the blocks!
Old 12/6/07, 9:02 AM
Well, it's actually pretty normal here in this neck of the woods because the stucco is always applied directly on the block. The block settles a bit and stairstep cracks show through the stucco. They are on about 10 out of 10 houses I inspect that are over a year old. I have them on my house.
The "normal" cure is to seal them when you paint the house, which with the weather here will be about every five years.
If the opposite of pro is con, the opposite of progress must be...
Old 12/6/07, 9:26 AM
Barry Adair's Avatar
I have a client that is considering having a block wall/fence built. I'll try and get over if this goes through and as work progress' to take some pix.
One step that has been successfully used by the stucco/EIFS contractor I recommend is using the fiberglass mesh as reinforcement. He has 8' walls that are over 10 years old that have no evidence of mortar joint telegraphing. We are on very expansive clay soils around here.
Adds a step in material application, costs a little more, but none of his walls have signs of this problem and he wont do a job without the mesh. I think he's a smart man that has incorporated the best of both worlds.
badair
ADAIR INSPECTION
972-487-5634
Residential-Commercial-Construction-EIFS-Infrared Thermography
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
life is the random lottery of events followed by numerous narrow escapes...accept the good
Moisture in slabs mcyr Structural 7 8/20/07 8:33 PM
bbbb mcyr Structural 1 8/19/07 11:26 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 8:53 PM
Step cracks in stucco on block home dbucknavich Structural 0 5/19/06 8:01 PM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
