Old 12/20/11, 8:31 PM
Sean Fogarty's Avatar
Default Stucco question for Carl
or anyone else with knowledge.
My inspection today was for a barrier system eifs that was damaged in the hail storm.
So the repair was to cut the entire face off the front of the home and redo in conventioal 3 coat.
They did leave the edges and corners. NO moisture barrier was in these areas. The just added paper, and wire on exposed places.
No weep had been installed yet.
Should it all come off or not? They are in the process of removing and repairing wood now. I have a feeling it won't be done right and the new buyer is well aware of all thats missing.
stucco-question-carl-8446-r-001.jpg   stucco-question-carl-8446-r-002.jpg   stucco-question-carl-8446.jpg   stucco-question-carl-8446-004.jpg   stucco-question-carl-8446-l005.jpg
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Need a home inspection in Florida? Check out InterNACHI's listing of Florida certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/20/11, 8:49 PM
Carl A. Brown's Avatar
Default Re: Stucco question for Carl
Sean
Can' see them good on my phone I am not home, Barry Adair if he is home.
Old 12/20/11, 8:51 PM
No big rush. I am sure it won't be done right never is here. Just when you get to it.
865-256-5397
Old 12/20/11, 10:27 PM
The weep for sure needs to be under the moisture barrier.
(If) it was mine I would want it all taken off and the (2) layers of moisture barrier in proper placement.
Is the reason they are not taking the quoins of is that the CON-tractor does not know how to do them again or cost for the homeowner?
Old 12/20/11, 10:30 PM
It looks like the moisture barrier is over the bottom nail fin on the windows now, that is like tucking your raincoat into your pants.
No backer rod and sealant joints anywhere? ( never/very seldom is)
Old 12/20/11, 10:35 PM
Hope OSHA does not see the scaffold.
Old 12/20/11, 10:45 PM
Do they use control/expansion joint there?
Old 12/21/11, 6:39 AM
They used one control joint so far, but its all not tore of yet.
As far as not tearing off, my guess is cost due to insurance money, but it may just be laziness.
The guy buing it is an insurance adjuster, so he understood quickly what the deal was. I am hoping for an intervention/contractor piss off.
865-256-5397
Old 12/21/11, 7:53 AM
Barry Adair's Avatar
on top of what's been identified
what weight is the lath?
is it nailed or stapled?
are kickouts present?
needs a detail-plan-drawing of how the stucco to grade minimum 2" above concrete flat work and 4" above dirt, windows, doors, penetrations & quoins will be integrated and water/weatherproofed and then they need to be able to apply correctly on site. if they can't produce a drawing and follow to the letter they'll produce a leaker!
basics more details are required for proper install
advanced
Carl would gobble 'em up and spit 'em out...
do over!
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 12/21/11, 8:27 AM
A good check list even if from another state!
http://www.mnlath-plaster.com/library/index.htm
http://www.mnlath-plaster.com/librar...ndbook2007.pdf
http://www.mnlath-plaster.com/librar...cklist_NEW.pdf
Old 12/21/11, 8:35 AM
Look hard at the moisture barrier and Lath section of the list.
Old 12/21/11, 9:18 AM
weep screed info under the moisture barrier.
http://amico-lath.com/lath/foundation_weep_screed.htm
Old 12/21/11, 11:53 AM
Rick Strand's Avatar
Rick Strand Rick Strand is offline
Fantastic discussion and links guys! I have yet to see a textbook installation of either hard coat stucco or masonry veneer and am not holding my breath.
Rick Strand, CPI
CAHPI Associate
Strand Home Inspections Inc.
Calgary, Alberta, Canada
Serving Calgary, Okotoks, Airdrie, Chestermere and Cochrane Alberta
Old 12/21/11, 12:35 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is offline
They can step back and admire the work at any time while free falling to the ground.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 12/21/11, 2:29 PM
ROBERT V. YOUNG's Avatar
ROBERT V. YOUNG ROBERT V. YOUNG is offline
Yep
CSST in Quebec would be up the contactors butt for the scaffolding.
No EFIS Knoxville TN.
Good energy saver.
Cost must be the same?
montrealbuildinginspectionservice.com
montreal-home-inspection-services.com
home-inspections-montreal.com
homeinspectionsservicesmontreal.com
ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC.
Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI)
OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816
Stucco question sradabaugh Exterior Inspections 3 3/6/08 4:38 PM
Stucco Question Tab M. Wilcox Exterior Inspections 9 11/19/06 2:46 PM
