Old 10/6/06, 7:51 PM
Barry Adair's Avatar
Default Super Flashing
Sorry for the lack of photo detail.
This is a commonly overlooked around here, head flashing construction defect.
They usually try and disguise it better.
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 10/6/06, 8:50 PM
Default Re: Super Flashing
Barry; Hope you wrote that one hard, I would not even call this a flashing.
Marcel
Old 10/7/06, 9:32 AM
Carl A. Brown's Avatar
You guys sure are hard on the carpenters.
That ranks right up there with my faux flashing.
http://www.badstucco.com/ff.htm
Old 10/7/06, 10:55 AM
Marcel,
No way, any metal, even when installed incorrectly, and globs of caulk is the builders and homeowners cure for moisture intrusion.
The wood door unit was not sealed at the stationary side sweep prior to installation. There is no sweep, flashing, or any other type of weather seal at the threshold. Now lets exacerbate the situation and add a few irrigation heads. The moisture levels were at 100% before the irrigation was tested. This won't make it to the one-year warranty.
Carl,
In this picture isn't the let-in Z flashing that's atop the frame the way to do it?
Aside from faux flash and caulking looks good from Texas?
I was taught to cut the 1x4 head trim at least 1/8" proud of the stiles and head flashing. Maybe I've been doing it wrong all these years? I'll have to research that one.
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 10/7/06, 11:09 AM
tneumann's Avatar
tneumann tneumann is offline
As a sprinkler contractor I can certainly appreciate that last picture....
Too much....
Old 10/7/06, 6:21 PM
Barry; Nothing wrong with the way you were taught, but there is plenty wrong with the picture you posted.
When are some of these builders going to learn? They were never taught I guess, are if they were, they have been doing it wrong for all this time.
Marcel
</IMG></IMG>
Old 11/12/06, 10:02 PM
kamata kamata is offline
Please Note: kamata is a non-member guest and is in no way affiliated with InterNACHI or its members.
What do you make of this?
Kelley
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 9:10 AM
Graphic needed for flashing under stone work lfoster Exterior Inspections 8 8/2/07 11:54 PM
no flashing; no inspection Leanne Jowers Exterior Inspections 97 5/9/07 1:11 PM
Step flashing at vertical wall? jlybolt Exterior Inspections 31 2/12/06 12:40 PM
