gbrasseur is a non-member guest and is in no way affiliated with InterNACHI or its members.
It is hard to see in these pictures, but just below the end of the shadow there is a "buckle" on the roofing. I could not get into the attic because the scuttle hole was closed off.
How would you guys call this out? Curious as to your ideas. Thanks, |
Greg,
there appears to be something going on in terms of settlement as indicated by the apparent seperation/settlement between the vent pipes and their flashings (if I am seeing that right) Certainly needs further evaluation from inside the roof space. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
I agree with Gerry, because I saw that line too, on both of the vents.
One of those vents is the biggest I have ever seen. What is it.? Wonder how long paint will last on a stainless steel product on two of these vents. ??? Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Greg,
You talking about the sway in the roof to the right of the vents? Probably warped trusses (if that's what you're referring to) |
Dale,
It is hard to see in the picture, but the roof (on the right side of vents) "buckles up". Just below the shadow of the plumbing/heat stack. Thanks to Marcel and Gerry for your answers also! You guys all help a LOT |
Pretty common here Greg, poor framing (as usual).....
I would think by looking at the picture.
Pardon my ignorance to yours here, but what the hell is a warped truss? If a truss was warped, would it not show up on the ridge? Curious. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Marcel.....a Hump, Bump, Warp, Curve....in wood at the top chords..... Junk trusses, they are very prevalent here anyway.... I have seen many residential roofs come out looking just like Gregs picture. And then again they could of made one a little bigger also, and used it, god only knows. |
tneumann is a non-member guest and is in no way affiliated with InterNACHI or its members.
I'm curious about this.....nailed shut? |
sspradling is a non-member guest and is in no way affiliated with InterNACHI or its members.
Could it be that the roof sheathing is not nailed properly?
Stu |
It "could be" anything...which is why I would want to get in that attic....or defer it if I could not......left my xray glasses at home.
Tony,
I have to satisfy your curiosity now |
I just might have pushed it up anyway.....can't hurt nothin.....but, you can always defer due to that.
It didn't appear to just have been sprayed. The scuttle hole was too smooth and you could not even see the lines where it was. In this case there was no way I was going to push on this and get a nice fat repair bill.
| A little on the Commercial side of things. | mcyr | General Inspection Discussion | 457 | 8/1/09 10:50 AM |
| Cracked shingles | pwigle | Exterior Inspections | 54 | 4/23/09 11:52 PM |
| Ice Gaurd membrane | dmacy | Exterior Inspections | 36 | 6/14/07 12:21 AM |
| Roof Repair? Maybe NO | jhagarty | Exterior Inspections | 9 | 2/15/07 1:19 AM |
