My brother-in-law is replacing his shingles and has had a couple of quotes that recommend a "synthetic" valley flashing material in place of metal. It is apparently used in the USA but new to Canada.
Does anyone have any experience with this product? (I don't have a brand name) I believe it is used inconjunction with ice and water shield. My questions would be: Longevity vs. metal flashing Tolerance of UV rays Tear resistance Permeability Thanks in advance. Joe Skrypka MBA RHI CMI The Home Inspection Guy Inc. Hamilton, Ontario Canada Membership No. NACHI050062193 |
homebild is a non-member guest and is in no way affiliated with InterNACHI or its members.
Valley materials depend entirely upon and vary with the type of roof covering being applied.
For asphalt based shingles, the 2003 International Resdiential Code allows two plys of mineral surface rolled roofing materials that meet ASTM D 249 to be used for open valleys. For closed valleys, 1 ply of a smooth roll roofing material compying with ASTM D 224 Type I or Type II can be used, or 'specialty underlayments' complying with ASTM D 1970 can be used. Most Ice and Water shields meet this standard for 'specialty underlayments.' The 2006 International Resdiential Code requires material complying with ASTM D 3909 or ASTM D 6380 Class M for asphalt shingles with open valleys. Closed valleys can have lining complying with ASTM Class S Type II, Class M Type II, or ASTM D 3909. The ASTM D 1970 can also be used for specialty underlayment. You would need to check Canadian Code and referenced Canadian standards to assure that any valley material that was being installed complied with Canadian standards regardless of where the material was made. Last edited by homebild; 3/31/07 at 7:57 AM.. |
I would stay with metal many installations I have seen the metal has been on for 3 sets of shingles . Rolled roofing seldom lasts one set even when doubled layered. Roy Cooke If I can answer any questions please send me email Roycooke@hotmail.com On an inspection and need immediate help call my cell 613-827-2011 |
Ice Shield
Joe Kormos A-1st Look Home Inspectors Inc. 630-201-0933 Your 1st Choice in Property Inspection Professionals www.a-1stlookhomeinspectors.com www.a-1stlook.com Let us look before you buy...for peace of mind “Thinking is the hardest work there is, that’s why so few engage in it. ” Henry Ford |
| Valley | dmacy | Exterior Inspections | 35 | 3/31/09 9:56 AM |
| Comp shingles over wood shingles | Matthew Hopkins | Exterior Inspections | 28 | 10/16/07 12:19 PM |
| Chimney flashing photo's needed: brick and stone done correctly | kshepard | Exterior Inspections | 6 | 10/13/07 9:10 AM |
| Valley flashing | rray | Exterior Inspections | 12 | 7/1/07 2:31 PM |
| NY NACHI Hudson Valley Chapter Meeting | pmaietta | Miscellaneous Discussion for Inspectors | 0 | 2/27/06 2:42 PM |
