looks like a bad mix that dried to fast. or had some other complication. i'd recommend total evaluation and repair from stucco EXPERT. what ever that means.
All of the above Jay.
The bad thing is it is in the same subdivision as most of these! http://www.badstucco.com/Leaks101_files/frame.htm They were done by the same stucco cooooonnnntractor! Over osb that just loves water and turns to mold candy. And swells when wet. Therefore makeing more cracks! Letting in more water. Homeowners dont stand a chance! http://www.badstucco.com/howwe.htm |
neither do their homes. i like the "mold candy" line. can i use that one.
hay, i might be younger than you. besides "sir" was a term i used in the navy that means Severly Iritated Rectum. or pain in the *** for short. but realy, thanx.
What makes you think I am older?
i don't, just that as inspectors go, i'm kinda on the young side. 31 to be excact. plus, Carl is a very old name.ha ha. j/k.
Well you got me!!! I have been doing stucco sence you were 4 years old!
And I am only 44! |
Carl:
1 Coat Stucco. Poor Installation. Recommend Siding replacement. What is the question? Joseph P. Hagarty, CMI joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
I was just looking for educated opinions! Personally I want to tell the people in the hole subdivision to sue the city for letting it happen! The codes officials really dropped the ball! And when I contacted them about it they just blew me off! Most of thessepictures were taken in the same subdivision! http://www.badstucco.com/Leaks101_files/frame.htm And then this is what happened in the state capitol. And it is wrong and things need to change! http://www.badstucco.com/howwe.htm And I figure if I keep throwing it out and around somebody will see it that has clout and start getting things changed! At this pointe these houses not only need to be resided but resheathed and probably structural work as well. And from what I understand it is a nation wide problem! I am just trying to give other people a heads up on some of the possibilities! OSB swells and turns moldy rather quick the more it swells the more cracks you guys will see in the stucco and the more it could leak water into the structure!! Sorry for the RANT! ps. Hard coat stucco issues are going to put EIFS to shame! |
Neither are unflashed windows and trim. Nor housewrap with the flashing over it instead of under it! With all the horizontal joints taped and sill flashing that is reversed lap! And that is how they say to install tyvek! So the houses are set up to fail and thats just some of the housewrap issues! Most of the premixed onecoat products on the market I have seen the sand is to fine and it causes alot of cracks! Last edited by cbrown1; 2/2/06 at 8:04 AM.. |
pcarter-old-04 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Carl,
A couple of questions on this. What type of mesh are they using on the OSB to apply the stucco to? Are they sealing the bottom edges of the OSB and if so how? Since wood products expand and contract during the seasons, how do they apply the stucco to counteract against expansion and contraction with two very different products? wood and cement Last question, since this does not appear to be a Traditional Stucco application, is this type of application considered a hybrid? I have noticed in my area, that the contractors here are starting to use this type of stucco application on new construction, so I am very curious on the service life and known problems associated with this. Thanks for your help. |
| Harry homeowner at his best | cbottger | Plumbing Inspections | 2 | 10/14/07 4:21 PM |
| U.S. Homeowner Woes Felt Around World | jburkeson1 | Miscellaneous Discussion for Inspectors | 0 | 8/12/07 11:36 PM |
| Federal Pacific System and Homeowner Wiring | pmagrone | Electrical Inspections | 2 | 8/2/07 6:30 PM |
| Homeowner thought he heard water running | rholtz | Structural Inspections | 12 | 12/12/06 12:09 PM |
| Homeowner special....defect or just informational? | tneumann | Plumbing Inspections | 7 | 2/9/06 3:32 AM |
